Fox Help Please
  • Thread starter Thread starter Morgan slater
  • Start date Start date Apr 24, 2016
1 of 2 Next Last
Morgan slater
  • Apr 24, 2016
Hello guy's, I just recently purchased a 1995 gt mustang thag has 160k miles on it and alot of mods done to it. The car runs very well for the mileage, the interior is in perfect shape. I just finally got the hang of driving stick. It is truly the most rewarding feeling, when you finally get the hang of shifting smoothly. I just wanted to know how much HP the car has with all the mods done to it.
BBK longtube headers
BBK off road xpipe
O2 sensor wire extensions
Flowmaster mufflers
High torque starter motor (indexable 4:1)
Msd distributor
Msd street fire coil
Ford racing plug wires
Air pump delete
EGR delete with simulator
Aluminum drive shaft
Cold air intake
Urethane transmission mount
Urethane engine mounts
Urethane sway bare links and sway bar bushings
Infiniti crossover (6x9 with tweeter 180w)
Other work that was done:
Upper and lower radiator hose
Both water pump hoses
New battery
Power steering pump rebuild
Fuel pressure regulator
MAF sensor
Also the cats have been removed. The computer has not been updated since the cats were removed and the engine light comes on.
Admin Dude
Jan 4, 1985
43,570
21,738
234
Box behind Walmart
Apr 25, 2016
  • Apr 25, 2016
I get the engine light. I get that the cats were removed. What computer update are you talking about? There's no update. The EEC remains what it was when it rolled off the assembly line to the day that it dies.
You other question(s):
BBK longtube headers - This is worth a little bit but on stock heads it's not noticeable
BBK off road xpipe - Same as above
O2 sensor wire extensions - Zero HP
Flowmaster mufflers- Zero HP
High torque starter motor (indexable 4:1)- Zero HP
Msd distributor- Zero HP
Msd street fire coil- Zero HP
Ford racing plug wires- Zero HP
Air pump delete-may 15 flywheel HP (that's like 4hp to the wheels)
EGR delete with simulator- Zero HP and probably lost some here
Aluminum drive shaft- Zero HP
Cold air intake- Zero HP (factory piece is cold air too)
Urethane transmission mount- Zero HP
Urethane engine mounts- Zero HP
Urethane sway bare links and sway bar bushings- Zero HP
Infiniti crossover (6x9 with tweeter 180w)- Zero HP
Upper and lower radiator hose- Zero HP
Both water pump hoses- Zero HP
New battery- Zero HP
Power steering pump rebuild- Zero HP
Fuel pressure regulator- Zero HP
MAF sensor- Zero HP
If it were stock and in good health, it makes about 190 HP to the wheels. So maybe 194 total if the motor is in great shape.
But hey! I love a good clean 94/95. Post up some pics when you get a chance!
Reactions: A5literMan and RaggedGT
CarMichael Angelo
8,909
234
Birmingham, al
Apr 25, 2016
  • Apr 25, 2016
And so you won't think that Noobz is being too short sighted in his HP assesment.....
I agree with everything he said.
Matter of fact, I'll take away ET for everything you listed that adds weight w/o a HP gain.
Reactions: bobs70stang and RaggedGT
Mustang5L5
Mod Dude
Feb 18, 2001
43,382
18,125
224
Massachusetts
Apr 26, 2016
  • Apr 26, 2016
I agree with them as well....excect that 160K wildcard. Who knows if the motor is making all it's rated power. Could be losing compression and such, and generally "tired". Or, it could be in great shape. Hard to say.
Also, fix the CEL. Run the codes and see what comes up.
Morgan slater
  • Apr 26, 2016
I'm a complete noob when it comes to cars so all the advice and knowledge is greatly appreciated. My ac compressor just broke which is always fun. I took it in to a mechanic my dad knows and he says km looking at 1500 dollars to fix it. Thoughts?
Morgan slater
  • Apr 26, 2016
MAF sensor- Zero HP
MAF sensor- Zero HP
Well as I just learned I'm going to need the eliminator chip, in order to get the engine light to go off. Correct me if I'm wrong. That's what I meant about "updating".
Davedacarpainter
SN Certified Technician
Nov 28, 2015
11,833
11,634
203
Discordia
Apr 26, 2016
  • Apr 26, 2016
Hey Morgan, don't sweat what seems like a bitchy attitude from some people. They really are great people that know enough about mustangs that I would've thought their heads should have exploded by now. They must wrap their heads in duct tape to be safe.
I think you have a great start with your mustang.
A lot of the upgrades you have you really won't feel the benefit without other things first.
The exhaust is nice to have in place, but the stock heads just don't breath well enough to get any benefit from them. So for right now, it probably makes your car sound much better than the restrictive stock exhaust.
Swap in a set of aftermarket heads with an intake and cam upgrade, then they will be really beneficial. Long tubes are a good thing, just better with a free breathing HCI (head, cam, intake upgrade). You will want to have them eventually.
The extender for the O2 sensors are needed when you put long tubes on.
The cold air intake is a good thing too, just suffers from the same problem as the exhaust. It'll flow more air to your motor, but the heads can't really take advantage of it. What kind do you have?
It's good to upgrade your bushings, after all the years our cars have been around, new bushings will give life back to the handling of them. The old rubber crap bushings wear out. Are your rear control arms stock with the stock bushings? That should be early on in your list of upgrades, it'll make your car handle better than new.
I agree with some less friendly folk that you should fix the cel first. I would assume part of it would be not having cats, look in the tech section for some of the checklists and fixes for this and to know how to check your codes thrown by the computer. Great help there from our own super genius @jrichker .
With 160k on the engine, it's really hard to tell where it's at right now. Kind of depends on how it was handled before, wether it had regular maintenance, or if it was thrashed about at high rpm. You'll have to find this stuff out as you go along.
So, fix the cel. Once that's handled, there is a plethora of upgrades that you can do to improve your car. Fact is, I think we even have a list for logical order on upgrading a mustang. Best to look at safety first, then go from there. Some people like to make the interior better first, others want their ride to breath fire first.
Good luck with what you got, ask questions as you go. Be specific on what you're looking for, and pictures, pictures, pictures with your questions. A description takes a thousand words, but one picture.......
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 26, 2016
  • Apr 26, 2016
Dump codes sticky
Look at the top of the 5.0 Tech forum where the sticky threads are posted. One of them is how to dump the computer codes. Codes may be present even if the CEL(Check Engine Light) isn’t on. I highly suggest that you read it and follow the instructions to dump the codes. http://www.stangnet.com/mustang-forums/threads/how-to-pull-codes-from-eec4.889006/
A/C problems - you can fix it yourself
Try eBay for some R12, it is running $20-$30 a can. You need 3 each 12 oz. cans and 6-8 oz. of R12 compatible mineral oil. The R12 compatible oil is like $20 a quart when you can find it. You may be able to find a combination can of R12 and oil together which may be cheaper than buying a quart of oil..
It is illegal for a company to sell any refrigerant other than R134 to a person who does not have an EPA 608 or 609 certification. That includes Freeze 12. However, individual sellers like those on eBay and, not affiliated with a store often do not ask for any certification information, they just want prompt payment.
See http://www.epa.gov/Ozone/title6/608/overlap.html for more details
R134a Air Conditioner Conversion and recharge instructions
Revised 14-Jul-2013 to add Low Pressure Cutout Switch adjustments for R134 & Freeze 12
Color Legend:
R134 specific items and instructions are in red text
Freeze 12 specific items instructions are in orange text
Note: R12 is available on eBay. Use the Freeze 12 instructions except use the R12 36 oz refrigerant charge with R12 refrigerant
Items and instructions common to both R134 and Freeze 12 are in black text
Tools and materials you will need:
Gauge set for recharging = $20-$120 – check out the pawn shops for a bargain before you pay retail.
See Harbor Freight Tools for an inexpensive gauge set.
Vacuum pump – I use an old refrigerator compressor = $20- $40 at used appliance stores, or go to the Dump and get one for free. Be sure to have some R12 compatible oil handy to keep it lubed up properly.
O ring seal kit = $8.
Replacement accumulator/dryer assembly with hose $55-$75
Alternative refrigerant – Freeze 12 – it will allow you to skip flushing the system and reuse the original accumulator/dryer under certain conditions:
1.) If the A/C system has not been open to air for more than an hour or so.
2.) Or if it hasn’t out of refrigerant for more than 5-7 days and the system is till sealed up with no open or disconnected lines. You need to be able to hear the hiss when depress the valve core in either one of the service ports. That tells you that there is still pressure in the system, which keeps out moisture and contaminants.
If either of the above is not true, you must replace the accumulator/dryer assembly.
Freeze 12 refrigerant: $15-$16 per 12 Oz can on eBay. Get 3 cans, 2 for the initial charge and 1 spare for a top off charge.
Use R12 compatible mineral oil, 6-8 Oz. This may be difficult to find or expensive (~$20 a quart). Sometimes eBay will have the oil/R12 combination cans, which have about 4 oz. R12 and 2 oz. oil in them. If you go this route, add the R12/oil charge first, then add the cans of R12.
Do not use PAG oil in a Freeze 12 system without flushing it first.
Freeze 12 refrigerant charge= 26-28 Oz plus 6-8 Oz R12 mineral oil on an empty system. A recharge may only require 2-4 OZ of R12 mineral oil if you only replaced a line, hose or seals.
A/C systems that have had a compressor failure must be flushed. Failure to do so will result in the floating trash left behind from the compressor failure destroying the replacement compressor.
R134a = $11-$16 a can – takes 2 cans.
R134a PAG or Ester compatible oil = $7-$12 for an 8 oz bottle .
Pump to force cleaning fluid through the system $20-$50 (may use compressed air to do the same thing).
R134a charging adapter = $13 (I cut mine up to use it with the R12 gauge set that I have had for a long time).
Plastic tools to disconnect refrigerant lines - 1/2" & 5/8" = $4 each.
Flushing agent - Discount Auto Parts has some flushing solvent in a 1 gallon plastic bottle - try that first. Or use Mineral spirits = $4-$5 a gallon, tetrachloroethylene =$5-$10 a gallon, takes 2 gallons of either one.
Miscellaneous hoses and fittings to adapt the flushing pump to the system, and the R134a adapter to the R12 gauge set = $15.
R134 Refrigerant charge is 26-28 Oz plus 6-8 Oz of PAG 100 oil.
R134 Conversion Instructions:
I did a R134a conversion on my 89GT, and used all stock parts. You will need to replace the dryer/receiver (about $75 if you get the one with the hose made as part of the unit), and should replace all of the rubber "O" ring seals as well. You will need to drain all of the oil out of the compressor and replace it with new R134a compatible oil.
R134 instructions (skip this if you use Freeze 12)
Keep in mind that to fulfill the requirements of the EPA, you are required by law to recover any refrigerant that still remains in the system. How (or wither or not) you accomplish this is up to you. Connect the charging gauge hoses to the service ports on the A/C (red gauge = high pressure, blue gauge = low pressure) and open the valves on the gauges to dump the remaining refrigerant (if any) into your "Freon recovery system", whatever it may be. Disconnect the charging gauges since you are finished with them until you are ready to fill the system with R134a. Next comes the nasty part – in order to get all the old oil out of the system, you will need to flush it with special flushing solvent, or mineral spirits (ok) or tetrachloroethylene (better, but may be hard to get). If you leave the old oil in place it will congeal and reduce the heat transfer in the condenser and evaporator (read that it won’t cool good) and possibly damage the compressor.
Disconnect the compressor and remove it from its mount to flush it with cleaning solvent. Pour about a cup of solvent into the suction port and turn the compressor center hub about 10 turns while shaking the compressor to move the solvent around inside the compressor sump. Drain the flushing solvent out and continue to turn the center hub by hand to force out any remaining solvent. Then fill it with oil: add about 6-8 oz of the new oil to the compressor large suction fitting. Turn the compressor center hub about 20 turns as you turn the compressor face up and face down to distribute the new oil inside the compressor. Catch and replace any oil that comes out of the compressor.
Connect the pump (I had an electric sump pump I bought for $20) to the hose from the high-pressure side of the compressor. Alternately, you could use compressed air to force the cleaning fluid through the system. I didn’t like to do this since compressed air has lots of moisture in it, which is death to A/C systems. Pump the cleaning fluid through the system and let it come out the hose that was attached to the old dryer/receiver. I used 2 gallons of mineral spirits and pumped it all through the condenser and evaporator. The expansion valve is located near the firewall in the high-pressure line of the evaporator, and may cause the cleaning fluid to trickle through the lines at a very slow pace. You may want to pump cleaning fluid through the evaporator and condenser separately to speed up the process.
All refrigerant types
Next comes the changing of all the old "O" rings so that the chances for leaks is minimized. The new R134 compatible O rings are green colored, so be sure that the replacement O rings are green. Use the plastic connector tools to separate the lines, place the extended collar part of the tool so that it faces the large part of the connector and push inwards: this expands the spring so that you can pull the tube apart. You may need a helper to push on the tool while you pull on the tubes to separate them. Install the new "O" rings: be sure to coat them with new oil when you put them in. Install the new dryer/receiver, refrigerant service port adapter on the compressor, add about more 4oz of oil to high pressure line and tighten up all the lines. You may have to add more oil when you do a system that has been flushed or new R12 installation. The total oil charge should be 6-8 oz. for all types of refrigerants. Close the hood, start the engine, let everything get warm under the hood, but don’t add the refrigerant or turn the A/C on. Connect the charging gauge hoses to the service ports on the A/C (red gauge = high pressure, blue gauge = low pressure) and open both valves, then connect the center hose to the vacuum pump. The purpose of this exercise is to heat up the system so that when you vacuum it all down (yes, you will need a vacuum pump- mine is an old refrigerator compressor), that all the air, vapor and moisture from the cleaning fluid vaporizes and is removed from the system. Vacuum it down for about 30 minutes, this should give you about 28" of vacuum or more inside the A/C system. I have a vacuum gauge "T" connected into the vacuum pump line so that I can accurately watch the vacuuming process. This is a good time to take a soda and sandwich break since it doesn’t go faster if you watch it.
the R134a service fittings on the system: the red goes on the high side and the blue on the low side. This will help others identify that a R134a conversion has been done on the system.
Typical low pressure side R134 coupling
Typical high pressure side R134 coupling
Charging instructions for all refrigerant types:
Remove the electrical connector from the dryer/receiver and jumper the two connections inside the wiring harness side of the connector together: this allows the compressor to engage in spite of low pressure/no gas in the system. Close both charging gauge valves, and then disconnect the center hose of the charging gauges from the vacuum pump and connect it to the refrigerant can tapper. Put the refrigerant can in the can tapper and screw it down with the can tapper valve closed, then open the valve. Loosen the hose at the center connection of the charging gauge set until the refrigerant squirts out: this purges the line of air and moisture. The refrigerant is added through the low pressure side of the system, so open the low pressure gauge valve to add the refrigerant. Start the car and take note of the idle speed, then set the idle speed up to about 1200-1500 rpm, and turn the A/C on inside and set the fan speed on high. Watch for the pressure on the low side to drop off as you are filling, and the refrigerant can will get warm and stay warm. This tells you the current can is empty and needs to be changed for a fresh one. Before you disconnect the can, be sure to close the valve on the refrigerant can tapper.
Watch the high side pressure on the charging gages and regulate the adding of gas to keep the high side pressure under 350 psi. You will probably need a fan in front of the car to keep the readings below 350 psi. I had to put the refrigerant can in hot water while I was charging the system with it, or else the can got so cold that it quit flowing. Use caution when you do this so that you don’t get water in the charging adapter when you change the cans.
R12 Pressures when charging is complete
When you have added the 32-36 oz. of gas, the high side will read about 250-300 psi and low side about 28-38 psi. No adjustments need to be made to the low pressure cutout switch.
Freeze 12& R134 Pressures when charging is complete.
When you have added the 24-28 oz. of gas, the high side will read about 250-300 psi and low side about 18-28 psi.
Freeze 12& R134 Low pressure cutout switch adjustment.
The low pressure cutout switches are adjustable. They should be set with the low limit about 18-21 PSI, the stock setting is about 25 PSI. Remove the wiring connector and there is a screw slot in between the connector pins. Turning it clockwise increases the trip pressure where it cuts off and counterclockwise decreases the trip pressure. I believe that each 1/4 turn counterclockwise lowers the cutoff pressure by 1 PSI.
After Charging refrigerant instructions, all refrigerant types
Turn the idle speed back to where it was, turn the A/C off, disconnect the charging gauges, and re-install all the caps on the service ports. Remove the jumper from the low pressure switch harness and plug it back on the switch connectors.
R134 only
Then put the R134a Service Sticker on, secure all the loose wiring on the system and you are done.
The typical sticker looks like this, yours may be different.
I hope it cools good, mine doesn’t get quite as cold as it used to driving around town.
Thanks go to WWW.ACKITS.COM for some of the graphics.
Check out their website for parts and the Auto AC Forum.
The above technical note is for informational purposes only, and the end user is responsible for any damages or injury. The end user bears all responsibility for proper recovery/disposal of any R12 refrigerant.
I have EPA 608 and EPA 609 MVAC certification. And yes, you can shortcut the process, but there are negative factors if you do. Sooner or later, something will cease to function like it should. Shoddy work is a time bomb ticking away, waiting to explode.
Reactions: Morgan slater, A5literMan, Boosted92LX and 1 other person
Boosted92LX
5,721
4,244
224
Apr 26, 2016
  • Apr 26, 2016
Rockauto.com has the compressor for $114.00 and the accumulator drier for $14. Always change out the drier when the system is opened. This is actually a simple job if you understand the task you are trying to accomplish. Ford also makes quick connect fittings (I call them unquick connect) that you'll need to pick up tools to disconnect. All auto parts stores have them. Basically, 1-change out the parts, 2-use a vacuum pump to pull a vacuum on the system, 3- use the gauge set to connect the freon cans and charge the system.
You can most likely find a you tube video to walk you thru it. Oh, and you can buy the vacuum pumps under $100 if you search online. I finally bought one last year. Amazon, I believe.
Reactions: Davedacarpainter
Morgan slater
#10
  • Apr 26, 2016
  • #10
Davedacarpainter said:
Hey Morgan, don't sweat what seems like a ****y attitude from some people. They really are great people that know enough about mustangs that I would've thought their heads should have exploded by now. They must wrap their heads in duct tape to be safe.
Thank you so so much for sharing your knowledge with me it is so incredibly valuable my current focus is on the AC, seeing as how I live in south Florida it is a must have. Apparently the compressor gave out and was burning up my belt. My local mechanic said it is going to cost around 1500. I'm very used to the wide spectrum of attitudes found on the World Wide Web nevertheless thanks for the heads up
Davedacarpainter
Nov 28, 2015
11,833
11,634
203
Discordia
Apr 26, 2016
#11
  • Apr 26, 2016
  • #11
Did the compressor give out, or just the clutch?
$1500 is a lot, how handy are you at home fixes?
Morgan slater
#12
  • Apr 26, 2016
  • #12
Thanks, yea I was looking into this and I am planning on doing to do it myself. My mechanic said that I would need to replace the AC system entirely to ensure that it has the longest life possible. At first I was thinking he was trying to rip me off considering the new compressor on late model restoration cost nothing.?
Morgan slater
#13
  • Apr 26, 2016
  • #13
My mechanic said the compressor is dead.
Davedacarpainter
Nov 28, 2015
11,833
11,634
203
Discordia
Apr 26, 2016
#14
  • Apr 26, 2016
  • #14
Just replace the compressor and dryer. Jeez.....whole system seems a bit of overkill to me.
Boosted92LX
5,721
4,244
224
Apr 26, 2016
#15
  • Apr 26, 2016
  • #15
Well, for one.. That's crap needing to replace the whole system. You need a new mechanic.
Second, if you are chewing up belts, it sounds like the clutch went out, and that's an even cheaper fix, because you don't have to open the system if it still is holding charge. Change the clutch out with the compressor on the car if possible, and it'll save a ton of money.
Reactions: A5literMan, Mstng93SSP and Davedacarpainter
Boosted92LX
5,721
4,244
224
Apr 26, 2016
#16
  • Apr 26, 2016
  • #16
In other words, the compressor might not be bad, just the clutch... Unless the compressor is locked up, and when the clutch engages it hurts the belt, but usually, you'll lose the seals on a compressor, then your charge, and the low pressure switch will prevent the compressor clutch from engaging way before a compressor locks up. It has happened, but not often.
Reactions: A5literMan and Davedacarpainter
Morgan slater
#17
  • Apr 26, 2016
  • #17
Well I know for sure there is no charge at all. It's completely empty:
Boosted92LX
5,721
4,244
224
Apr 26, 2016
#18
  • Apr 26, 2016
  • #18
Ok then you need a compressor. Remember the drier also.
Morgan slater
#19
  • Apr 26, 2016
  • #19
Is all this fairly easy for a beginner to replace ? How much time do you think?
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Apr 26, 2016
#20
  • Apr 26, 2016
  • #20
Morgan, if you are not up to doing the job, PM me and I can give you the names of two guys in S fl that I can refer you to who are honest and know these cars inside and out.
Reactions: stykthyn, A5literMan, Morgan slater and 1 other person
1 of 2 Next Last
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • dan50
  • Jul 18, 2026
dan50
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
squeak93
SN95 The Unicorn
  • HANO Motorsports
  • May 18, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2025
HANO Motorsports
