Help Quick Please!!!!!
  • Thread starter Thread starter wildstang87
  • Start date Start date Jun 16, 2005
W
wildstang87
96
  • Jun 16, 2005
hey everyone, im having a new problem. it seems to be a hot start problem. i will use today as an example. i was cruising down the interstate, about 75 or 80 for about 18 miles, everything was fine. i got off and pulled straight into the gas station, filled up, and hoped back in (5min max) and the car barely started, like the starter was locking up, but still cranked, it was surging bad at idle, and running very very rich(i think, like a carbed car that is flooding out) got right back on the interstate, and it skipped bad for about a mile and then cleared up. what does this sound like?? i was thinking timing, but would like to know what all of yall think. now i have a backfire in the exhaust. another question is what size gas tank do i have?? oh, its a 87 gt, basically stock speed density, besides no smog or cats.PLEASE, ANY SUGGESTIONS??? IM RACKING MY BRAIN......
W
wildstang87
96
  • Jun 16, 2005
Anybody??? I Know Someone Knows What This Could Be.... Please..
C
crunchie12268
599
Manhattan, KS
Jun 16, 2005
  • Jun 16, 2005
check the codes, check your IAC and TPS voltage. What about 02 sensors? TFI Module (they are prone to heat). I think you can test the TFI if you start the car up and tap the TFI module, if it starts acting up... then hey theres your problem. What about EGR? Check the Vaccuum.... I don't know alot, but I know it sucks when you really need a response quick and there is 50 people in here who don't seem to know anything.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jun 16, 2005
  • Jun 16, 2005
Well, it probably smelled 'rich' becuase when you were cranking the motor, it was dumping fuel that pooled. Once it fires up and burns off all that fuel it will smell terrible.
How is your car's tune? I haven't really had a hot start problem before but it might have something to do with your speed density computer..
HISSIN50
34
129
Jun 16, 2005
  • Jun 16, 2005
If checking vac, your SD motor should have near 20" hg at warm idle. CHeck your MAP sensor and the line to it (if there is a crack in the line, that can create some issues. It would end up making the puter think you are into the gas when you are not [rich]).
I would yank codes too (since your car has no CEL, you dont know if it tossed one).
Good luck.
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Electrical F150 ECU in a Foxbody? Idle surge help
  • 93royalblue
  • Sep 10, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
Mustang5L5
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
