HELP!!rocker arm adjustment!!
  • Thread starter Thread starter 67staaang
  • Start date Start date May 13, 2008
67staaang
132
  • May 13, 2008
hey guys..
im hearing a really loud ticking noise.. i finally open up the valve covers and waah la! heres what i see....
<a href="http://s202.photobucket.com/albums/aa102/trypleoptiks/?action=view&current=IMG_4928.jpg" target="_blank"><img src="http://i202.photobucket.com/albums/aa102/trypleoptiks/IMG_4928.jpg" border="0" alt="Photobucket"></a>
<a href="http://s202.photobucket.com/albums/aa102/trypleoptiks/?action=view&current=IMG_4929.jpg" target="_blank"><img src="http://i202.photobucket.com/albums/aa102/trypleoptiks/IMG_4929.jpg" border="0" alt="Photobucket"></a>
<a href="http://s202.photobucket.com/albums/aa102/trypleoptiks/?action=view&current=IMG_4933.jpg" target="_blank"><img src="http://i202.photobucket.com/albums/aa102/trypleoptiks/IMG_4933.jpg" border="0" alt="Photobucket"></a>
Can you guys guide me through the process of adjusting my rocker arms so they are straight and eliminate the ticking issues?
thanks for helping a newb!!
Edster
500
League City, Texas
May 13, 2008
  • May 13, 2008
It looks like one of the holes for the rocker arm stud was drilled a little off center, a bent push rod, or your rocker arms are out of adjustment. Hopefully its the latter. I take it you have the original solid lifter Hi-Po cam?
If so it will be noisier than a stock or even a hydraulic performance camshaft. Make sure your rocker arm clearance is at spec. That will quiet it down some but it will still be I'm not sure what it is you will have to check the factory manual if you don't have one I strongly recommend you get one. GOOD LUCK!!
classic boost
709
canton, oh
May 13, 2008
  • May 13, 2008
this link will walk you thru it: http://www.flowtechinduction.com/technical.htm#Valve
Brake-hose-to-drum Fit Issue.
  • 70mstang
  • Mar 2, 2018
Classic Mustang Specific Tech Mar 2, 2018
70mstang
Ongoing Mod List
  • bwkelley76
  • Jan 23, 2015
5K
2005 - 2014 S-197 Mustang -General/Talk- Apr 16, 2015
SlammedGT
C
Engine why is this oil leak happening? (pic)
  • craig3x
  • Feb 2, 2013
2K
Classic Mustang Specific Tech Feb 28, 2013
SHEDRED
  • Locked
Expired Stock 75 amp alternator
  • mikestang63
  • Nov 17, 2012
  • Engine and Power Adder
Engine and Power Adder Nov 17, 2012
mikestang63
Iron Oxide, AKA RUST!!!
  • firemansam
  • Aug 10, 2011
2K
Classic Mustang Specific Tech Sep 24, 2011
firemansam
