help!!!!....running problem
  • Thread starter Thread starter cornholio47
  • Start date Start date Sep 20, 2004
C
cornholio47
90
winston salem, nc
Sep 20, 2004
  • Sep 20, 2004
Ok i need alot of help here this has totally got me and my friends stumped. Ok we just put a motor in my car, i had the motor bored .030, explorer upper and lower, e cam, and gt40p headers. ok we put the motor together and correctly i might add ( i have alot of faith in justin ). well got it in the car and try to start it it runs then shuts off. ok so i replaced the fuel pump and filter, now it still wont start...injectors not working... so i replaced those. now the fuel problem is over...but now when you start it it will try to idle and its missing pretty badly and it pops through the intake and the exaust... we checked..double checked and triple checked the timing everything is right. we have checked the map sensor, mass air, IAC, distributor, TFI module, everything electronic except the computer. before we put the motor in the car had been sitting for 6months and the battery has been dead. thought maybe the computer was in default but i highly doubt it. it acts the same way even if you pull the spout connector out so i would think that that eliminates the computer. but if you rev it above 2500 it clears up and runs just fine. im lost can anyone help me here....please!!..
nito88stang
2,012
Fullerton, California
Sep 20, 2004
  • Sep 20, 2004
Might just be the cam. Try raising the idle. If you've never been around a cammed car with a very low idle then it sounds like the car is goin to hell.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 20, 2004
  • Sep 20, 2004
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
C
cornholio47
90
winston salem, nc
Sep 20, 2004
  • Sep 20, 2004
i was reading about the KOEO test. ive done that before, but it says you have to get the car to operating tempateure. we cant even get it to run that long.
C
cornholio47
90
winston salem, nc
Sep 20, 2004
  • Sep 20, 2004
ive also been around a cammed car alot for the past 3yrs bc all of my friends own modified mustangs. but we have gotten together on this problem again and we might think it is a vaccum leak it must be an awful big vaccum leak to cause it to run that bad. any suggestions on where it could be coming from? the hose going from to the intake to the vaccum cluster on the firewall is hooked up. any other hoses or leaks anybody can think of??
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 20, 2004
  • Sep 20, 2004
Here's some help for the vacuum lines - Red line goes to the fuel pressure regulator.
Speed density cars: One goes from the manifold to the MAP sensor on the firewall behind the upper manifold.
Mass Air cars: NO connection goes from the manifold to the BARO sensor on the firewall behind the upper manifold.
There is a cluster of vacuum lines on the passenger side wheel well. A plastic sleeve covers the colored part of the lines: push it back to see the colors I am referring to.
One white line from the vacuum line cluster goes to the rear smog pump valve. One line goes from the manifold to the red line on the vacuum line cluster. One green line from the vacuum line cluster goes to the EGR, The black line from the vacuum line cluster goes to the from smog pump valve.
One large vacuum line from the front goes to the carbon canister control solenoid.
One large line goes to the vacuum tree
Some help from Tmoss (diagram designer) & Stang&2Birds (website host) with a picture...
http://www.veryuseful.com/mustang/tech/engine/images/88Stang5.0Vacuum.gif
You can dump the codes without having the engine running. Just follow the directions I posted, then post the codes. The computer will find a number of problems with an engine that will only crank and not run.
C
cornholio47
90
winston salem, nc
Sep 21, 2004
  • Sep 21, 2004
well i think we found the problem...the cam might be out of time itself. we are guessing and hoping that it might be off a tooth or two bc that would not be noticeable unless you took the front end apart and looked. hopefully this will be it..hopefully. i just dont know what else would cause it to pop through the intake and exaust.
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
