I am setting up FRPP 373 gears and wondering if it would be best to go right back with factory shims or what? I have installed all new bearings, seals, locker, axles, everything. And what is it that I see people talking about the numbers stamped on the gears that list the gear depth requirements or something along those lines. What are all the numbers stamped on the gears? I have installed it all once and the wear pattern did not seem right. I checked it and rechecked it with the ProForm Pinion Depth tool and it comes up to be .002 thicker shim on the pinion than the factory. Should I just use the factory, because the tool and myself could make that much error. What does anyone think, what would you do? I just want to make sure this thing dont whine and I dont break gears. The wear pattern from first assembly seemed a little to much toward the heel and not as deep in the teeth on the ring as it should be. It wasnt bad, but not as desireable as everything I read. Any advise is great.
