HELP! sohc to DOHC swap
DOHC_00' GT
Having a hard time getting the tranny out of my 2000 mustang GT. I have waiting a 2003 Lincoln Aviator motor to drop in. I have removed all bolts that mount tranny to engine but it still will not come out?
is it an auto??if so u have torque converter bolts.. and 5 speed then u have to pull it towards the back of the car and then it should come out..also check between the motor and the tanny there might be a dust sheild thing on it holding u up
it is a 5 spd and yes there is a dust shield. ill remove that first thing tomorrow morning and see what that does. thanks. but, i have been pulling the hell out of it to the rear, and prying it apart but still just doesnt want to come out.
coramprat said:
How many bolts did you remove? I had 7...5 you can see and two at the top you can't unless you look from the enging bay. Also the starter had to come out on mine.
I was thinking of same thing. Make sure you get all bolts out. Top 2 is bit tricky to get to. and starter have to be out too.
after that, I think i just wiggle the heck out it to get it out
