  • 1994 - 1995 Specific Tech
Help!!! Starter won't engage
  • Thread starter Thread starter red50
  • Start date Start date Jul 20, 2004
R
red50
28
  • Jul 20, 2004
I have been working on my car for about 3 months now... Rebuilt motor on stock block but in the process i relocated the battery to the trunk... I am at the point where the motor is back together but when i go to turn the motor over, the starter doesn't engage at all. Battery is in the trunk and shutoff switch is in the rear bumper. From there the Positive cable goes straight to the positive terminal under the hood and feeds everything from there. Did i do something wrong?
Thanks in advance,
Red50
G
greg@berkeley
1,172
minnesota / university of california, berkeley
Jul 20, 2004
  • Jul 20, 2004
i recently had a problem w/my starter not turning on. my problem was as simple as the power wire to the alternator not making good contact even though the little harness was plugged in.
hopefully your problem is this simple! it's worth checking out, anyway.
H
HazMat404
1,749
Jul 21, 2004
  • Jul 21, 2004
do you hear it spin at all or it just doesnt do anything?? ive had my starter pull away from the flywheel a few times before but you would definately hear the starter spinning tho
R
red50
28
  • Jul 25, 2004
nothing still...
I do not hear anything when i try and turn it over... Any other thoughts or ideas... Alternator is connected fine.
Thanks
G
greg@berkeley
1,172
Jul 25, 2004
  • Jul 25, 2004
Thanks
oops, i'm retarded. when i said power wire to the alternator, i meant power wire to the starter. how is the connection at the starter?
R
red50
28
  • Jul 25, 2004
Figured it out...
Found the problem. I check all the connections on the starter and everything looked good, so i got out the trusty volt meter and i was not getting anything at the small black wire ( signal wire) on the starter. Put the car on a lift and traced the wire back to the battery post/fuse block. THere is a strange quick disconnect on the wire and turns out, no poer was getting through the connecter. cut out the connecter and replaced it with spade connectors and boom, thing cranks. Surprised i have not heard of this problem before on anybody else's car. Oh well, Thanks for all your input...
Red50
HISSIN50
34
129
Jul 25, 2004
  • Jul 25, 2004
have you had the batt in the trunk for awhile now or is this new?
batt charged? put a jumper battery on it and see if it cranks. ditto for running "helper" grounds. could just be a bad ground, connection, battery, or rotted cable.
good luck.
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
89 LX Electrical Troubles
  • fun331
  • Oct 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 27, 2025
fun331
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
  • dan50
  • Jul 18, 2026
dan50
