  • SN95 4.6L Mustang Tech
Help!!! Starting problem.
  • Thread starter Thread starter JayDPee
  • Start date Start date May 18, 2005
J
JayDPee
14
  • May 18, 2005
Okay, here's the deal. I bought a 96 Cobra last week. Has under 40,000 miles, runs great, but a couple of owner "mods" that suck. Guy tried to put in a manual fan and ran hot to neutral. He fixed it, but the fan connection is melted. He wired it with a wall switch. Over the weekend the fan failed to come on and the car overheated. Fixed all that. I've run the fan off pin #46 now, flushed the system, did all the maintenance, everything looks good.
The problem now. Now the car won't start. When I turn to the RUN position I get power to everything, everything looks good, then I turn the key and all the power goes out and nothing happens. The guy put in a crappy kill switch, which might be the problem. Not sure yet. I've checked the grounds and the battery and they look good.
Now the help part. He "lost" the fuse cover, so now I don't know which fuses or relays do what, and because of the overheat the panel got wet. Anyone able to help with a picture of the fuse layout? I noticed the row of 3 relays is missing the one closest to the engine.
Thanks.
tomustang
Psychotic Member
3,434
McLean Hospital
May 18, 2005
  • May 18, 2005
owners guide will work, same with a chilton/haynes manual. sorry can't scan either for you.
J
JayDPee
14
  • May 18, 2005
I have Haynes and it doesn't have the fuse panel layout. I don't have the owners manual either.
I've checked battery voltage, 12.5V, no drain once I turn it over, stays above 12V. The Starter relay clicks and the starter solenoid clicks. I've run a jumper cable to ground from the negative terminal, that didn't work. I guess the last thing would be the starter itself.
Any thoughts?
tomustang
Psychotic Member
3,434
McLean Hospital
May 18, 2005
  • May 18, 2005
damn it dosent, the chilton does i know.
tomustang
Psychotic Member
3,434
McLean Hospital
May 18, 2005
  • May 18, 2005
check the kill switch in the trunk
Jsun3701
124
Virginia
May 20, 2005
  • May 20, 2005
Ford Website
IF you log into the Ford website, you should be able to enter your VIN and download a owners manual.
highvolts
20+ Year Stangneter
Sep 1, 2003
436
Ohio
May 20, 2005
  • May 20, 2005
OR....
Just go here..
http://www.motorcraftservice.com/vdirs/retail/default.asp
Click on OWNER INFORMATION
YardSpecial
2,664
MT
May 20, 2005
  • May 20, 2005
http://www.motorcraftservice.com/vd...bs_serv_all_new&TYPE=OWNERGUIDE&menuIndex1=22
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
