Okay, here's the deal. I bought a 96 Cobra last week. Has under 40,000 miles, runs great, but a couple of owner "mods" that suck. Guy tried to put in a manual fan and ran hot to neutral. He fixed it, but the fan connection is melted. He wired it with a wall switch. Over the weekend the fan failed to come on and the car overheated. Fixed all that. I've run the fan off pin #46 now, flushed the system, did all the maintenance, everything looks good.
The problem now. Now the car won't start. When I turn to the RUN position I get power to everything, everything looks good, then I turn the key and all the power goes out and nothing happens. The guy put in a crappy kill switch, which might be the problem. Not sure yet. I've checked the grounds and the battery and they look good.
Now the help part. He "lost" the fuse cover, so now I don't know which fuses or relays do what, and because of the overheat the panel got wet. Anyone able to help with a picture of the fuse layout? I noticed the row of 3 relays is missing the one closest to the engine.
Thanks.
Thanks.
