help!!! tachometer and battery and temp. gauge stopped working???
dfresh5050
106
I changed my ignition switch and after I put the new in, the tach. and temp. and battery gauges all stopped working?? then i tried putting the old switch back the gauges still wont work.
I need help!!
Did I loosen a wire somewhere or blow a inline fuse or something??
I checked the fuse box and all those fuses were fine.
All help would be appreciated, thanx.
I am having a brain fart. If those gauges are all on the same side of the cluster, I would look for a loose wiring connector/connection.
Good luck.
i might try replacing gauge voltage regulator, you might have fried that accidentally..
but yeah they are all on the same side,
is ur fuel and oil pressure gauges still working?
my fuel and oil pressure gauges r working fine. what does that fuse look like and where is it exactly?? any help is appreciated, thanx
r the tach and oil pressure coming from the same wire, it looks like they seperate but they go through the same coil of wires?????
The gauges on a given side of the cluster tend to share a harness (and if that harness is disturbed, one side will work and the other might not). There is no fuse that I know of. It would be an electrical connector/connection or a ground wire which might have been tampered with that could cause this issue.
