Help to Identify the parts of this Solenoid
monk302
742
New Jersey
Please help me identify the areas listed as A,B,C,D on this solenoid. I believe they are as following moving from left to right.
FROM LEFT TO RIGHT
A: Positive
B: Start Signal
C: ???
D: ???
The specific reason I am asking that is I am attempting to finalize wiring up my EFI harness. Thanks,
Mike
One will be start and the other ignition. Should be labled with a "S" and "I".
If you are converting to EFI, you may not need to connect the "I" terminal to anything. Will depend on your alternator setup tho..
I am running a stock alternator. With the Ford Fuel Injection harness it says that the purple goes to "start" and red goes to "positive." I am correct in assuming that "B" would be start? I didn't see any S or I's.
Thanks,
Sorry, just re-read your post.
A(big connector) = Positive
B (small connector) = start signal
C (small connector) = ignition (+12V when key is turned to start AND run)
D (big connector) = Power that goes to starter when start signal received.
You are correct that B = start.
Sorry I can't help you with the alternator wiring, I switched to a single wire alternator years ago.
Thanks,
B- is the start term.
red will go to batt side A.
The efi gets it pos to coil while cranking from a differant signal wire.
which would post C be attached to with stock system.
PB
Posted by bottlefed:
Not so sure about C (small connector) = ignition (+12V when key is turned to start AND run)
I thought it's purpose was to output the full 12v to the coil while cranking (start position only - NOT run)
Once running, then the coil gets the 8-9v from the resistor wire to keep the points from burning up...
I think you are correct. My mistake.
