HELP *Urgent*
I can't believe only a few people picked up on that. A spinning noise continuing after he takes the key out pretty much narrows it down. What other accessory spins, has key off power, and would cause a no-start situation after it runs for too long of a time?
Glad you got it. With a partially charged battery or stressed battery (cold = diminished deep cycle capacity), the solenoid contacts can weld together while trying to crank it.
For future ref, if one removes the slide-on terminal on the solenoid and the noise stops, the ignition switch or starter interlock circuit wiring has shorted to key-on or constant power. Often, this will make the starter engage each time the clutch pedal is pressed down (the clutch switch closes and closes the interlock circuit).
If that does nothing and it takes removing the starter cable from the solenoid, that suggests the solenoid went south.
