Glad you got it. With a partially charged battery or stressed battery (cold = diminished deep cycle capacity), the solenoid contacts can weld together while trying to crank it.
For future ref, if one removes the slide-on terminal on the solenoid and the noise stops, the ignition switch or starter interlock circuit wiring has shorted to key-on or constant power. Often, this will make the starter engage each time the clutch pedal is pressed down (the clutch switch closes and closes the interlock circuit).
If that does nothing and it takes removing the starter cable from the solenoid, that suggests the solenoid went south.
