Help w/ timing marks on 66 289
  • Thread starter Thread starter 88dragtop
  • Start date Start date Oct 26, 2006
88dragtop
198
Glastonbury,CT
Oct 26, 2006
  • Oct 26, 2006
I am trying to time my car but can only see like 4 or 5 lines on the balancer which look like 2 degree increments and what looks like 16 at the end of them. My late model has +,- 30 degrees. Anyhow I drew a line in the middle just to see where it was at and it's way off but i'm not sure what the hell I'm at on the balancer. What should be on the stock balancer for marks? It's clean and there isn't a ton of paint on it but I can't see any more lines. Yes, the vac advance is pulled.
thanks
67topless
203
Raleigh, NC
Oct 27, 2006
  • Oct 27, 2006
I believe it only goes to ~ 16 degrees on the balancer. The 30 + degrees is your total timing which takes into account what value has been selected in your distributor (you add your initial timing to this value and that gives you your total timing).
I recently had to pull my balancer and lightly sand the rust off of it and give it a good shot of clear coat. I couldn't read it at all.
HTH's
Scott
D
D.Hearne
11,730
south louisiana
Oct 27, 2006
  • Oct 27, 2006
The BTDC side goes up to 30 degrees, the ATDC side only goes 10. Take a drill with a wire wheel and remove all the paint from the marks, then either paint over them with white or use a chalk, then wipe the excess off.
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Long Time Coming
  • 85gtCOBRA
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 18, 2025
2Blue2
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
