HELP What Carb do I need
  • Thread starter Thread starter 69 Mach 393
  • Start date Start date Mar 14, 2004
69 Mach 393
76
SW Missouri
Mar 14, 2004
  • Mar 14, 2004
What carb do you recomend for the motor in my signiture.I was thinking 750 cfm, do I need electric choke,vacume advance,ect.I am not an engine tuner so I need to keep it as simple as possible and try to get it right the first time.Also I need to know what type headers to look for 69 Mach 1. Any help appriciated
10secgoal
2,801
San Diego
Mar 14, 2004
  • Mar 14, 2004
PROFORM!! I built one with a 650 holley core $125. Plus $100 for mainbody plus $45 for AN fuel log. Plus a freshen up kit. $275 for a 750 holley dominatoror hp series is basically what it is. You can get vacuum sec or double pumper. summit has them on sale right now.
rbohm
6,698
550
204
tucson,az
Mar 14, 2004
  • Mar 14, 2004
i would use a 750 carb, perhaps even and 850 carb. that engine needs airflow due to the poor rod/stroke ratio.
69 Mach 393
76
SW Missouri
Mar 14, 2004
  • Mar 14, 2004
What is the problem with the rod stroke ratio.
F
fastcoupe68
368
nj
Mar 14, 2004
  • Mar 14, 2004
There is absolutely nothing wrong with the rod ratio in a 408 I would choose a 750cfm demon or holley I personally prefer the demon money wise you cant beat its out of the box performance.
D
Denny Wiedman
110
nj
Mar 14, 2004
  • Mar 14, 2004
carb
69 mach 393 your engine is close to mine, sportsman block A351, steel crank rods alum pistons from probe, 7qt milodon oil pan, roush 200 heads flowed to 250@.500 lift,180 on the .ex, 9.8.1 comp ratio, custom comp hy roller 288-293-236-242-555-576-108, vic jr manifold, 750HP DP carb worked from BIGS, 1\3\4 supercomps, edelbrock water pump, msd billet dist, my engine builder said 750 would be ok for my engine i was thinking 950HP but i'll see how it fares on the chasis dyno this spring, 69mach1 408w, i need torque then high end HP hope my engine will put some good numbers down if not back to the drawing board. good luck with yours.
BOSSMAN98
212
Kings Mountian, NC
Mar 14, 2004
  • Mar 14, 2004
My 393 in my 67 runs a 950 double pumper. If I put anything smaller on it the car slows down about 3 tenths.
67GTCOUPE
653
Land of Ice and Snow
Mar 15, 2004
  • Mar 15, 2004
Dood:
Get a 750 Pro Vac from www.quickfueltechnology.com
Or if you want all out racer.....get them to custom build a double pumper.
They will build it to your motor specs.
All I can say is my 750 Pro Vac is the Best Carb I have ever seen!!!!! It performs like EFI..........let me tell you it kicks azz.....and it was reasonable.
The customer service is top notch........talk to Marty Brown.....the guy knows how to make power!!!!!
69 Mach 393
76
SW Missouri
Mar 16, 2004
  • Mar 16, 2004
Would a holley 750 Avenger be a good carb for this engine.This is not a racer just a weekend toy.
67GTCOUPE
653
Mar 16, 2004
#10
  • Mar 16, 2004
  • #10
Trust me......the ProVac 750 from Quick Fuel is WAY, WAY more carb....for about the same cash. It is completely modified and tested by the guys who build $1000.00+ race carbs for all types of racing!
Do yourself a favor.......BUY ONE.......you will not be dissapointed! I would call them and talk to Marty.....give him your engine specs and he will build the carb to your set-up.......it will blow your socks off!
PS: I have absolutely nothing to do with the company......I am simply one very happy owner.
10secgoal
2,801
San Diego
Mar 16, 2004
#11
  • Mar 16, 2004
  • #11
67GTCOUPE said:
Dood:
HAHAHA MArt'y awesome ain't he ?
dodgestang
1,360
Cecil County, MD
Mar 16, 2004
#12
  • Mar 16, 2004
  • #12
What is your projected use? If its a street car and you want to drive it to shows and what not.....go with the 750 vacuum secondaries.
Here is an example though.....
My stroker (which is a very different motor than yours) is a 408 cleveland.
I just made 330 or so RWHP with a 770 vacuum secondary carb.
The motor made 393 RWHP with a double pumper that was flowing 850.
My car with the AOD is getting 15 miles to the gallon (AOD, 9 inch rear, 4.11 gears) with the 770 carb. That to me is very impressive given the power it makes. Once I switch to the 850 full time I expect that number to go down drastically because of the nature of double pumpers.
I would expect your motor to run good with a 750 VS and run better with an 850 VS and even better still with an 850 DP.
67GTCOUPE
653
Mar 16, 2004
#13
  • Mar 16, 2004
  • #13
In my experience......yes. The guy knows his stuff and gives you great support.
I hope you aren't being sarcastic, because those guys deserve more than that BS.
67GTCOUPE
653
Mar 16, 2004
#14
  • Mar 16, 2004
  • #14
I think that if it is a street car that sees the occasional strip, you are way better off with a vacuum sec carb.......the throttle response is better for street seeing as the secondaries respond to engine airflow needs.
The ProVac 750 that I have flows well over 800cfm wet! Yet it retains wicked throttle response due to the set-up and vac secondaries.
I sold my Holley 750 DP to buy the ProVac.......BEST move ever!
bnickel
5,640
lubbock, texas
Mar 16, 2004
#15
  • Mar 16, 2004
  • #15
well i really like my demon carb, and like the rest of the guys i would recommend a vac secondary for the street especially with an automatic
10secgoal
2,801
San Diego
Mar 18, 2004
#16
  • Mar 18, 2004
  • #16
No, was having a few problems with the air bleeds.
10secgoal
2,801
San Diego
Mar 18, 2004
#17
  • Mar 18, 2004
  • #17
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
Y
Speed density 302 to carb 351W
  • yaboity
  • May 29, 2026
  • Fox Engine Swaparoo
Fox Engine Swaparoo May 29, 2026
AeroCoupe
Need help ordering a oil cooler and filter relocation kit but don't know what I need
  • Aiden Brown
  • Aug 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 14, 2026
squeak93
I need help with an 06
  • boviske underwood
  • Oct 30, 2025
  • Services - Tuning, Welding, Mechanic, Body Work...
Services - Tuning, Welding, Mechanic, Body Work... Oct 30, 2025
boviske underwood
A
need help and advise
  • amps1956
  • Oct 14, 2025
  • Other Auto Tech
Other Auto Tech Oct 21, 2025
Mcmahst
