Help, When to apply seam sealer?
  • Thread starter Thread starter 68FBJJZ109
  • Start date Start date May 29, 2005
68FBJJZ109
357
Easton, PA
May 29, 2005
  • May 29, 2005
My Mustang is now completely down to metal. Does the Seam Sealer need to by applied while it's bare metal, or can I out a base coat of epoxy primer to protect the car, then seam seal it.
dennis112
1,561
36
79
Amish Wonderland of Central PA.
May 29, 2005
  • May 29, 2005
Give it a coat of epoxy primer before using Seam Sealer. Epoxy sealant is much more resistant to rust.
Ford did not do it that way when they built our cars and this led to problems because moisure often got trapped underneath the sealant. The result ended up being rust that you did not see until it was too late.
Remember that Ford was building an expendable grocery getter and had not indended for them to be classics that are still adored 40 years later.
68FBJJZ109
357
Easton, PA
May 29, 2005
  • May 29, 2005
Great thanks alot that helps alot. Also before we prime it, we had planed to quick prep it, and sand it do the the fact there is light surface rust, from people touching it. Should we sand it the use the quick prep wax/ grease remover, or clean it sand it then clean it again. The reason I am asking is I am having a little disagreement with my partner in crime and I dont want to get the Fastback off to a bad start.
dennis112
1,561
36
79
May 29, 2005
  • May 29, 2005
Cleaning it first prevents you from sanding wax and grease into the small scratches you will make.
The PROPER way is to clean it, sand it, clean it again, then wipe it down with a proper rust inhibitor (if you have it) just before priming. As always, spray a light coat first and allow it to flash off a little before going heavy. Allow it to dry overnight before seam sealer.
Make sure your seam sealer can be painted over. If you are concerned, later, after the sealer has dried, you can apply another coat of primer over it before you paint.
68FBJJZ109
357
Easton, PA
May 29, 2005
  • May 29, 2005
Awsome thanks alot, I appreciate the info.
Paint and Body Cowl Pan
  • jeremyzcook82
  • Sep 13, 2026
Fox 5.0 Mustang Tech Oct 3, 2026
Rcdgl
R
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Tuesday at 7:51 AM
AlexM556
A
Paint and Body Is this seam sealer?
  • AnthonyA1234
  • May 3, 2024
Fox 5.0 Mustang Tech May 3, 2024
AnthonyA1234
I don know what im doing!
  • Sha_lala_pookie
  • May 5, 2025
1965 - 1973 Classic Mustangs -General/Talk- May 11, 2025
Sha_lala_pookie
New gal in San Diego
  • Mustang Momma
  • Feb 11, 2026
  • The Welcome Wagon
The Welcome Wagon Feb 11, 2026
Mcmahst
