Help with 90 GT with AOD
InjunSHZ
Hi y'all. I'm new to this forum, and think I am posting this in the correct place.
I have a 90' Model Mustang GT 5.0. It has a built AOD with the 4R70W Gearset. I had to drop the trans to change the Torque Converter, and replace the Front Pump Seal. I unbolted the Throttle Valve arm from the trans, and now that I hooked it back up, it won't move. It is the Cable type of Throttle Valve. I would like some sort of diagram to see how this is exaclty suppose to hook up. Thanks for any help.
Just to let it be known. I did the old trial and error trick and found out that I did indeed have the TV arm hooked up wrong. The TV arm needs to ride on the high side of the Shift arm at the trans, with the long part of the TV arm pointing to the rear of the car. Hopefully this will help anyone that may run into the sam problem.
