help with codes
  • Thread starter Thread starter bobbyd
  • Start date Start date May 17, 2007
bobbyd
312
San Antonio/Los Angeles
May 17, 2007
  • May 17, 2007
hey guys i recorded a video of me getting some codes on my car only to find out that my digital camera only records 30sec max. I still managed to get some codes recorded on the video can you guys tell me what codes they are.
Also i will try to record all of it using my camcorder to figure out all other codes. thanks
heres the video http://youtube.com/watch?v=st9jboeV_RU
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 17, 2007
  • May 17, 2007
??? I can't tell anything. You need to count the flashes and post the numbers or buy a code reader with a LCD display.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
bill302
2,131
alabama,gadsden
May 17, 2007
  • May 17, 2007
you have a code #11 System checks OK..... you need to post what happened after the code 11 flashed....the codes will flash 3 times as this first code did thats how you read them it flashed 1 beep then 1 beep then paused which is 11 it will do this 3 times then go to the next code...
bobbyd
312
May 17, 2007
  • May 17, 2007
thanks yea i think im going to get me one of those since its kind of hard to understand the beats
bobbyd
312
May 17, 2007
  • May 17, 2007
so it plays each code 3 times in a row? didnt that code 11 only do it 2 times?
AnthonyR23
661
Ontario
May 17, 2007
  • May 17, 2007
only flashes each code twice... eg.. 21 45 would be flash flash pause flash break flash flash flash flash pause flash flash flash flash flash break and then it will repeat again...
AnthonyR23
661
Ontario
May 17, 2007
  • May 17, 2007
very easy to understand.. don't waste your money on the reader!!!!
bobbyd
312
May 17, 2007
  • May 17, 2007
aight I will try it again tomorrow and see what codes i get hopefully I write them down correctly
stephenwilson18
11
  • May 18, 2007
bill302 is right, code 11 means everything is fine, if it beeps out twice that means that's all the codes it has. Depends on whether you are doing the key on, engine off (KOEO) test or key on, engine running (KOER) codes, you may want to check both and there are some other tests you can do as well with that scanner, Dont waste your money on that other scanner.
bobbyd
312
May 18, 2007
#10
  • May 18, 2007
  • #10
I was doing the KOEO. I will go and try it now with the engine on and see what i get.
Splitter for Saleen front valence?
  • 2000xp8
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 3, 2026
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
F
Help with air bag code 2293
  • Felwinters
  • Apr 23, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Apr 23, 2026
Felwinters
F
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
