help with codes
David Pepiton
662
68
49
Laveen, Arizona
The night was rapidly approaching the wind was howling gun shots could be heard in the distance and there I was balls deep in my engine bay at my south phoenix home dinner was in the oven and the wife was nagging me to come in. But the battle raged on the ignition coil must be changed and thee was no better time then now to complete this task. Once this was completed I fired her up and she ran perfect looked at the at the sun and said well better check my vac lines and of course many were broken so I made a trip to my second home and picked up some new vac lines and elbows and other bits a pieces. Well after everything is back to how it was I take her for a spin and my check engine light starts to flash at me but only while accelerating. So pulled out the scanner and here's what I've got
Koeo dtcs:11 and 31
Koer dtcs: 12 and 26
The only lines I replaced are the egr valve and both smog pump valves I did them one at a time to not get them confused the one the was broke was the diverter valve and didn't have the check engine light flashibg at my while it was broken.
Code 11 is the code for the computer passing its internal self tests. No code 11 and the computer is bad or you have wiring problems.
CODE: 31 (KOEO) - EVP circuit below minimum voltage. Vref (5 volt reference voltage supplied by the computer) missing or broken wire or bad connection in circuit. Use a DVM to check for 5 volts on the orange/white wire. If it is missing, look for +5 volts at the orange/white wire on the TPS or MAP sensor located on the firewall near the center of the car. Use the black/white wire for the ground for the DVM.
With the sensor removed from the EGR and still connected, press the plunger and watch the voltage change on the brown/lt green wire. Pull the passenger side kick panel and measure the voltage at the computer. You will need to remove the plastic cover over the wires and probe them from the backside. A safety pin may prove very useful for this task. Use pin 27, EVR input (brown/lt green wire) and pin 46, signal ground (black/white wire) to measure the voltage. The orange/white wire is Vref and should always be 5 volts -/+ .25 volt. Be sure to measure Vref at the EGR sensor to rule out any broken wires or bad connections.
Measuring the voltage at the computer helps you spot broken wiring and intermittent connections.
See the graphic for the 10 pin connector circuit layout.
salt-pepper-10-pin-connectors-65-jpg.68512
Code 12 -Idle Air Bypass motor not controlling idle properly (generally idle too low) - IAB dirty or not working. Clean the electrical contacts with non flammable brake parts cleaner at the same time.
Recommended procedure for cleaning the IAC/IAB:
Conventional cleaning methods like throttle body cleaner aren’t very effective. The best method is a soak type cleaner used for carburetors. If you are into fixing motorcycles, jet skis, snowmobiles or anything else with a small carburetor, you probably have used the one gallon soak cleaners like Gunk or Berryman. One of the two should be available at your local auto parts store for $22-$29. Take the solenoid off the body and set it aside: the carb cleaner will damages some types of plastic parts. Soak the metal body in the carb cleaner overnight. There is a basket to set the parts in while they are soaking. When you finish soaking overnight, twist the stem of the IAB/IAC that sticks out while the blocker valve is seated. This removes any leftover deposits from the blocker valve seat. Rinse the part off with water and blow it dry with compressed air. The IAC/IAB should seal up nicely now. Once it has dried, try blowing through the bottom hole and it should block the air flow. Reassemble and reinstall to check it out.
Gunk Dip type carb & parts soaker:
Code 26 - Mass Air Flow out of range – MAF
There are three parts in a MAF: the heater, the sensor element and the amplifier. The heater heats the MAF sensor element causing the resistance to increase. The amplifier buffers the MAF output signal and has a resistor that is laser trimmed to provide an output range compatible with the computer's load tables.
The MAF element is secured by 2 screws & has 1 wiring connector. To clean the element, remove it from the MAF housing and spray it down with electronic parts cleaner or non-inflammable brake parts cleaner (same stuff in a bigger can and cheaper too).
Look for 12 volts across pins A & B.
The MAF output varies with RPM which causes the airflow to increase or decease. The increase of air across the MAF sensor element causes it to cool, allowing more voltage to pass and telling the computer to increase the fuel flow. A decrease in airflow causes the MAF sensor element to get warmer, decreasing the voltage and reducing the fuel flow. Measure the MAF output at pins C & D on the MAF connector (dark blue/orange and tan/light blue) or at pins 50 & 9 on the computer.
At idle = approximately .6 volt
20 MPH = approximately 1.10 volt
40 MPH = approximately 1.70 volt
60 MPH = approximately 2.10 volt
Check the resistance of the MAF signal wiring. Pin D on the MAF and pin 50 on the computer (dark blue/orange wire) should be less than 2 ohms. Pin C on the MAF and pin 9 on the computer (tan/light blue wire) should be less than 2 ohms.
There should be a minimum of 10K ohms between either pin C or D on the MAF and ground.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif[/b]
so i cleaned the IAC with brake cleaner and blew in the bottom hole and i can feel air coming out. im assuming that means its bad
The soak type cleaner is the only thing I know of that will loosen the serious deposits found in automotive parts. If you can get a inexpensive replacement IAC, do that. Otherwise, spend the $$ for a gallon of the soak type cleaner.
Yeah I dropped it in about an hour ago I thought I had a 5gallon left but I guess my brother took it from the shop. Well I took the egr off as well and its soaking also. I work for a autoparts company so I'm sure I can get one for a good price.
well just got everything put back together and man what a difference after I got it back together I turned her over and of course the idle was a little high since the motor was cold but after sitting in my driveway just idling rpms dropped to about 700-800 after I finished cleaning up (putting all the tools in a bucket) I took it for a spin no check engine light flashed at all I took it to 4500 and not a hiccup and other then my neighbor staring at me while I drifted around the corner it was great. ill be checking for more codes later today and see how she does.
