help with error codes, have EEC codes now what?
aparker813
51
these are the codes i got from an autozone test
P0352 Ignition Coil B Primary circuit fault.
P0353 Ignition Coil C Primary circuit fault.
now what needs replaceing? is it coil packs or somethin worse?
The service manual shows a bunch of steps. Do you have a coil pack or coil on plug? If you have the coil on plug (COP), it says to determine which ones are not firing. 352 and 353 look like it's cylinders 2 and 3. Then you have to test a bunch of stuff.
It might be time for you to download the service manual.
http://www.jonheese.com/fordcds/
Or you could try and replace COPs 2 and 3 and see what happens. Or maybe swap the COPs with other cylinders and see if the codes follow the cylinder. Then you'll be more certain its the COP.
Wait, are the COPs interchangeable? I don't know.
