At the moment i'm running a blown 331 engine with a mechanical fuel pump with boost enrichment on a 650 cfm blow through QFT holley carb.
Problem is that the car has really low fuel pressure of 3 psi and it doesnt run good also (think the pressure is way to low).
Thinking about ditching the whole mechanical fuel pump and go with a electric pump with fuel regulator.
What do i need ?
Fuel pump
Backoff plate for engine
regulator
relais
Is that it ? or should i need more to switch to electric pump ?
Also wich one should i take, there are so many pumps on ebay and wich fuel pressure would be best to start with, 7-9 psi i read for holley's ?
Need to order everything abroad so need to get the right stuff and in one order (shipping costs...)
Thanks !
What do i need ?
Fuel pump
regulator
relais
Thanks !
