help with gauge cluster wiring
  • Thread starter Thread starter Pod
  • Start date Start date Jul 14, 2006
Pod
71
Cambridge, UK
Jul 14, 2006
  • Jul 14, 2006
I've got hold of this 170mph gauge cluster from a 1988 Saleen.
The bad news is that the ribbon cable on the back has been cut.
Does anyone know what type of connector should be attached, and how long the cable is?
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jul 15, 2006
  • Jul 15, 2006
you might be able to find someone to solder that back together. I do know that you can get a replacement for the older ones..(pre 79) so I would think you could get one for that....or try one from a car from the scrap yard
DEFWISH
87
Wichita, Ks
Jul 15, 2006
  • Jul 15, 2006
Or you can just give it to me.....
jk, ya a replacement might work
Pod
71
Cambridge, UK
Jul 15, 2006
  • Jul 15, 2006
I can solder it, the problem is, I don't know what size of shape connector should go on the end of the ribbon cable. ie what to solder it to.
dastang2
2,020
tx
Jul 15, 2006
  • Jul 15, 2006
why not just transfer all the gauges to your stock cluster housing and then you wouldn't need to doler anything, right
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2026
2000xp8
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
Electrical Oil Pressure Gauge IN Dash Cluster Unresponsive
  • Nine Finger Wrenching
  • Jan 7, 2025
Fox 5.0 Mustang Tech Jan 8, 2025
85GTStangGuy
