  • 1994 - 1995 Specific Tech
Help with gauge install
  • Thread starter Thread starter 95Cobra302
  • Start date Start date Mar 11, 2006
95Cobra302
394
Daytona Beach, FL
Mar 11, 2006
  • Mar 11, 2006
I'm installing a pillar mounted water temp guage and might need some help with the wiring. Usually i run the wires to the fuse and wrap it around it, but some dude at the parts store said not to do that. I need a light illumination, and an ignition power so everybody know the easiest and best way to hook'em up, and maybe some pics. Thanks
94 Cobra 5.0
114
Ft. Riley, KS
Mar 11, 2006
  • Mar 11, 2006
i would take the 12v and the illum off of the radio connections since they are the easiest to get to without messing with the fuse box
95Cobra302
394
Daytona Beach, FL
Mar 11, 2006
  • Mar 11, 2006
Well i need the illumination to come on only when i turn the headlights on, and not on all the time. Which might happen if i hook it into the radio ones.
HISSIN50
34
129
Mar 11, 2006
  • Mar 11, 2006
He is talking about the dimming of the radio display, not the actual display (which is integral to the LCD screen inside the radio).
For my pillar, I tapped into the dimmer wire right at the headlight switch - it's a super short run to the pillar from there.
Good luck.
95Cobra302
394
Daytona Beach, FL
Mar 11, 2006
  • Mar 11, 2006
I remember i had the instrument bezel and headlight switch off but i couldn't see the wire. How do you get to it?
SeriousSN95
74
daytona beach FL
Mar 11, 2006
  • Mar 11, 2006
its the brown wire on the headlight switch for ill.
95Cobra302
394
Daytona Beach, FL
Mar 11, 2006
  • Mar 11, 2006
Ok thanks, I saw how this guy hooked everything up to his rear defroster wires so tomorrow I'll pull the bezel off and check those wires.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
