Help with head unit install
tribune
27
I purchased the Alpine CDA-9827 head unit, and need to know what the best wiring adapter and installation kit is for my 99GT (with the mach 460).
Thanks,
-trib
if your ripping all the old out, might as well run lone power / ground / acss. wires from the engine, then run RCA's back or speakers direct - bypassing the ford harness.
if you plan on using the ford harness just walk into any local stero shop and get a radio install harness, be sure to use soldered connections for mot reliable connections, although connectors will work almost as good!
