Help With Hooking My Tach Up
89_5.0GoneBad
18
TN
I just bought a Tach from my friend, It's a SunPro Tach with a shift light on it. The mustang I am putting it on is an 89 Carb Motor. How do I hook it up? I have never hooked one up before. I think the Tach has 4 wires on it.
Thanks :SNSign:
The tach signal wire from the tach should go to the negative side of the coil.
Then you have key-on 12 volts to the tach, ground and lighting input (fuse 13 is on the dimmer circuit, or you can choose a source of your choice depending upon where the tach will be mounted).
Good luck.
Good luck.
Thats how I wired mine, its very easy and I suck with electrical stuff. 1/2 hour tops.
My tach has 4 wires .. The red & the black I know what they are for (hot & ground) but I got a white and a green one. Where do they go?
Thanks :SNSign:
The instructions for the tach should show that one of those wires goes to the neg side of the coil and one should be positive for gauge lighting.
Good luck.
