Help with monte carlo bar
  • Thread starter Thread starter 65notch
  • Start date Start date Jul 2, 2005
65notch
303
661 Cali
Jul 2, 2005
  • Jul 2, 2005
hey guys, i got my monte carlo bar installed in my 65 coupe. but i have a problem....My hood wont completly close. i have a 100% fiberglass cowl hood that i guess is set up a lil different than a stock hood? it looks to be that the hood is hitting the bolts on the top part of the mount. i can close the hood all the way but it puts a little bit of stress on it.
Anybody else have this same problem?
Any suggestions on what i can do?
thanks guys
BullittFB
89
  • Jul 2, 2005
Try using some flush-head bolts.
65notch
303
661 Cali
Jul 2, 2005
  • Jul 2, 2005
i thought about that. but how is it going to keep from spinning when i tighten the nut? if it has the square key under the head...i dont believe it would work well since the holes in the bracket are round...
I
iamlance
127
  • Jul 2, 2005
U should b able 2 find flush type bolts with a torx or allen hole in them.
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Jul 2, 2005
  • Jul 2, 2005
Call around and ask for a "Button head" bolt. We use them a lot in the industrial environment.
faultlessfocus
28
Indiana
Jul 2, 2005
  • Jul 2, 2005
I used a sawzaw to cut off a little bit of the extra bolt on my mounts. Did the trick well, and you can still remove the nuts if you are careful when doing it.
A
a.vannoy
90
  • Jul 2, 2005
Are the hood bumper rubbers in place?
65notch
303
661 Cali
Jul 2, 2005
  • Jul 2, 2005
yes
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Jul 2, 2005
  • Jul 2, 2005
I agree with button head socket bolts. I use them occasionally at work and they can get you a little extra clearance. Luckily I have the option of facing or turning down the head in a lathe if I need. They often have a deep socket for the Allen key so there is still alot of area to grip the wrench.
69 Capecod
97
Cape Cod MA.
Jul 2, 2005
#10
  • Jul 2, 2005
  • #10
didnt some one in this forum drill a hole so the bolt went into the hood rail. I can swear I read that somewhere.
P
Hello, core supports for '86 vs '90-3, i need some answers if anyone knows
  • Pony Dr.Mike
  • Mar 14, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 15, 2026
95steedamustang
D
2006 GT Windshield Cowl install
  • Daddidio
  • Mar 12, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 12, 2026
Daddidio
D
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Friday at 3:18 PM
2000xp8
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
