Help with my cam selection
jb1dsl
566
Marianna, Fl.
I need some opinions for my cam. It is a roller 347, 10.8\1 c.r., edelbrock rpm heads, edelbrock rpm intake,c4 w\2500 stall, 3.55 rear gears.
Crane recommended number: 449561 222\240@50,112 lobe sep, 563\584lift
Comp cams recommended: 35-430-8 224\224@50, 110 lobe sep, 560\560 lift
I was also looking at a FMS X303, trickflow stage (what stage), edelbrock rpm.
My heads will accept 575 lift so Im wanting to stay away from the crane cam and want one off the shelf not a custom grind.
This car is a street car, it may never see a track so it needs to be street friendly. I will not be driving it far distances, 30 miles max, and gas mileage is not a factor
Give me your opinions on these cams and other choices, please.
Thanks
Heres some CompCam camshafts that I really like the specs on:
XE276HR-12: 224*/230* - .544"/.544" - 112* lsa - 2200 to 6200rpm
XE274HR-12: 224*/232* - .555"/.565" - 112* lsa - 2200 to 6200rpm
Edit: The X303 might not be a bad choice, although I think the above cams are better. If you go Trick Flow I would go with the stage 1 (opt for 1.7 rockers if you choose), the stage 2 is actually more of a blower grind (very wide LSA), and the stage 3 is too much. The second cam you listed with it's 110* LSA would be a lopier idle, which might not be what you're looking for in a street car.
Well hard to say really, I'm no cam expert, but I would say any roller cam is going to be designed around fuel injection considering they both switched in the mid 80's. I usually try to look more at the heads, intake, and intended purpose when choosing a cam. I don't know if carb or fuel injection would be an issue....something to ask a custom cam grinder or maybe on of the manufacturers....I'm sure there are probably little differences they can do between the two.
