- Jun 27, 2004
- 153
- 0
- 16
I just had a new radiator installed and i have been having a problem getting all the air out of the system. I thought the my thermostat was stuck and i replaced that and i still have the same problem. Then i reliezed that the part of the radiator the the cap screws onto doesnt look like its bent properly and when i squeeze the top radiator hose i can feel air and coolent escaping the cap. It shouldnt be leaving the cap correct? it should go into the overflow if anything i think. Also the system doesnt pressurize so i thought it was the cap so i replaced that and it still doesnt keep pressure. Could the lip of the ring be messed up from the factory or should i look else where for the problem. There are no other leaks in the system that i have found yet. Thanks
