Help with removing upper intake.
fujifrench2k4
17
Lutz
Aight i got all the bolts off besides the number 5 Bolt. And well it had small nut on it that i removed , then theres a line thats attached to the upper that is on top of the other nut holding the intake on. Know what Im talking about? Anyways if you do , how did you get that line off so i can get to the nut?
I just did this last night. That line you are speaking of is a support of something but I don't remember what. Anyway follow it to the end of it and you will see another nut holding the other end down. Take that nut off and your in business. Hope this helps.
ok, lets see here from memory i can recall.
- remove air intake tube
- 4 torx screws for upper plate
- 5 of 6, 1/2" bolts for intake
- 6th in stud, remove the nut, ground wire, 1/2" stud below
- throttle cable, cruise cable
- unplug egr, tps, iac
- front of intake, canister purge vac. hose, (could have clamp)
- back of intake, thick line to vac. tree, two small lines, FPR, canister
- coolant lines to spacer
umm, i think that's it.
