Help with Rust Hole
  • Thread starter Thread starter palerider94
  • Start date Start date Nov 12, 2006
P
palerider94
573
  • Nov 12, 2006
Attached is a picture of a rust hole I have on the bottom of my door. Have on both sides. I know the best way is probably to cur it out and weld in new piece but don't have access or have not done any welding.
I thought I could grind down and then put rust bullet of or por-15 on it and then fill in with por-15 putty - then paint on iside of door and out. Would this hold up?
Thanks
351w_swap
263
  • Nov 12, 2006
I wouldnt just put filler in it, you will develop cracks and other problems; plus filler diminishes the value of the car. Take it to a shop or find a friend to help you out. Where are you located? Maybe someone on the forum can help.
P
palerider94
573
  • Nov 12, 2006
I was afraid I'd hear that I'm located in Valpo Indiana. Any body work help would be great. My plan is to do full body restore in next couple of years. Doors and qtrs have a lot filler in them - plan on putting new skins & qtrs. Just getting all other stuff out of way - brakes, suspension, etc. Thougt I might be able to slow down until ready to take that on.
krash kendall
1,258
Aldergrove, B.C. Canada
Nov 12, 2006
  • Nov 12, 2006
If it is just a temporary fix untill you restore it then you may want to consider cutting the rust out, making a small panel with a flanged edge, and then use panel adhesive to attatch it. If you don't have a flanger and air hammer, you can buy flanging vise grips.
351w_swap
263
  • Nov 12, 2006
If you are going to re do the doors later anyways, the filler would be alright but if you are trying to fix it now so all you have to do is the skins later, weld in some new sheet metal. I would help but im in west michigan (a little to far away).
I had to do something like this on the front of my door but it was the entire front corner. Someone just filled some huge holes with lead so I cut all that out and welded in some new steel. After that I had a ton of grinding and shaping but it looks good now.
fasttback
471
Northern CA
Nov 12, 2006
  • Nov 12, 2006
For a temp fix - use POR15 or the equivalent right away and putty/filler (if you want). The POR15 will stop the rust and seal it, while the putty will fill it (I don't think it will be that bad to have an extra drain hole down there, as long as you seal the bottom with POR15 to prevent further rusting - temp only of course).
Also - you probably already know this, but clean the inside of the door out so it can drain like it's suppose to and remove any flaking rust within the door before painting.
Platonic Solid
1,960
CT-USA
Nov 13, 2006
  • Nov 13, 2006
Thanks
As has been said, as long as you do both sides it'll be fine. Here's my rear window channel repair:
73 Rear Window
73 Por-15 Channel Repair
D
Rust on Window Belt
  • DuluthFoxbody
  • Wednesday at 8:36 AM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Wednesday at 3:32 PM
DuluthFoxbody
D
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
Kleinjj27
K
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
T
Fox Help Request: Clutch Cable Installation on T5 Swap — I Can’t Find the Mounting Hole
  • TDM389
  • Feb 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2026
nickyb
Rust under side window weatherstrip
  • swe13
  • Jun 5, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 5, 2025
swe13
