help with speedo cable
  • Thread starter Thread starter slo65
  • Start date Start date Aug 21, 2004
slo65
448
Southern California
Aug 21, 2004
  • Aug 21, 2004
ok guys my cars all together and running (just about running) for the first time in a long ass time, well when i dropped the tranny in the firstplace i told my friend to disconnect the speedo cable but he didnt we dropped the tranny and goodbye speedo cable , but anywho i bought the new speedo cable/speedo gear/speed sensor, now my next question is how the f am i gonna get to the back of the speedo? is there any trick to this? and also the cars running like i said, but the idle is very very irratic it surges like crazy, i was told this would fix it... so is it true should the car run ok after i put this in? thanks in advance
TheBocSez
652
Converse, TX
Aug 21, 2004
  • Aug 21, 2004
I dont know about a speedo cable fixing an erratic idle, I believe the VSS only control cruise control.
To connect your cable to the speedo, you have to remove the instrument cluster. Most of the bolts are 8mm. Take the dash plate under the steering wheel off, remove the platic trim around the steering shaft (where the ignition key is) Remove the light and hazard switches, Remove the gauge bezel 2 torx head screws on the top near the windshield and one on the lower right corner where the center console comes to the dash. Remove the 4 or 6 bolts holdng the instrument cluster to the dash and pull the cluster out some. Its a tight fit, but you can reach your hand back there, release the clip to remove your old one. After you have routed your new one, it snaps into place in the back of the speedo, not at easy as it sounds, takes some flexablilty and patience. Make sure you feel the cable lock into place, give it a gentel pull, it shouldnt just slide out. Then put it back together. Make sure you grease the cable. Have fun, Ive done this twice, once to replace the cable and again to replace the speedo. I have a vert so it seemed a little easier since I could lower the top and have some headroom.
slo65
448
Southern California
Aug 21, 2004
  • Aug 21, 2004
thats what i was afraid of, oh well i just had the column apart to put in a new ignition switch it wasnt too hard i guess, then again changin the bezel in the 65 was a pita, but ok i'll take a stab at it later, so does anyone have any more imputs as far as the irratic idle goes? the car has cruise control (dont know if that makes a difference) the guy basically said with the speed sensor and stuff it should fix it, any other ideas as far as the car running like ish?
slo65
448
Southern California
Aug 21, 2004
  • Aug 21, 2004
ttt
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
  • dan50
  • Jul 18, 2026
dan50
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
