  • 1994 - 1995 Specific Tech
Help with Starter removal
  • Thread starter Thread starter CivicEater
  • Start date Start date May 16, 2004
C
CivicEater
579
  • May 16, 2004
I am taking mine out becuase I suspect its gone and I am done being stranded.....I have the car jacked up and got the bottom bolt out but cant get anything in to touch the top one....anything else have to be pulled....haynes said it can be done just like this but I dont have a lift like them ......
Thanks
mytight95
2,605
Dothan,Al
May 16, 2004
  • May 16, 2004
you will need a 1/2 inch wrench, stubby if you have one, and it is easier (i think) to get that one from the top, instead of the bottom. Either way get ready for some aggrivation.
good luck
jason
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
May 16, 2004
  • May 16, 2004
I think I used a long extension to get the top bolt out of mine... Cant remember.
94TURBO5 O
2,509
VA
May 16, 2004
  • May 16, 2004
It's a major PITA but it will come out with some tedious work. I think I took the solenoid off of my stock one to get to the top bolt. Here is what you are dealing with if this helps. This is a small high torque starter so it may be different than the size of your starter if it is stock.
1105
May 3, 2003
3,841
Daytona Bch, FL
May 16, 2004
  • May 16, 2004
i think this is how i got to it...
C
CivicEater
579
  • May 16, 2004
Thanks for the pics guys....From the looks of it you had your heads and headers off.....Can I do it with those in place? I dont have a swivel so I guess I need to go buy one tomorow.
1105
May 3, 2003
3,841
Daytona Bch, FL
May 16, 2004
  • May 16, 2004
You dont have a swivel? I thought every garage had one...
C
CivicEater
579
  • May 16, 2004
LOL
Every garage SHOULD have one .... Mine will tomorow anyway...You didnt remove anything to get yours out right Zach?
1105
May 3, 2003
3,841
Daytona Bch, FL
May 16, 2004
  • May 16, 2004
My LT header on that side was unbolted and moved a bit cause I was taking it off... You should be able to slide it out just gotta play around with it for a bit
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
D
4.6L 4 valve Sleeve
  • DangStitches
  • Oct 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
coil pack bracket
  • SteveG94GT
  • Apr 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 11, 2026
SteveG94GT
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
