Help with suspension setups
  • Thread starter Thread starter redmenace66
  • Start date Start date Jun 7, 2005
R
redmenace66
  • Jun 7, 2005
Hey i was needing a little help with some possible suspension setups. I need to be able to corner and handle well. Though I am on a budget could i get some ideas of a budgetless and budget?
Yeah i guess car specs would be helpful....
289 engine 68 coupe relatively all stock....for now
geostang351
946
Danb., CT
Jun 7, 2005
  • Jun 7, 2005
Ummm.... How 'bout a little info on your car. What kind of car, year, engine make model.....
G
grego37
576
Fresno CA
Jun 8, 2005
  • Jun 8, 2005
Sway bar
Export brace
Subframe connectors
Lowered ride height
Perfromance shocks
Good tires
Perfromance springs
A-arm drop, wedge kit, or aftermarket arms.
etc............
2bav8
2,511
Mesa, AZ
Jun 8, 2005
  • Jun 8, 2005
Reduce as much weight up front as possible to improve the weight distribution of the car.
Roller spring perches, Adjustable Strut Rods go a long way as well.
eric n
875
Bakersfield, CA
Jun 8, 2005
  • Jun 8, 2005
Can not recommend loudly enough tcp supframe connectors and their "x cage". Also very little is more important to your handling than the rubber holding you on the road. I went with the biggest sway bars front and rear I could find, added the subframes mentioned above, kyb (cheap and pretty good) shocks, 620 springs, 5 leaf rear springs, 245 60 15 Kuhmo 712's, a 6 point roll bar and the difference is night and day. You can definately go more expensive and get a better set up, but what I've got is clearly enjoyable.
I also threw in a flaming river steering box and power steering delete. I'm very happy.
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 11, 2026
roldy
R
L
5.4 4v base ignition timing table help.
  • leoleo
  • Aug 16, 2026
Digital Self-tuning Forum Aug 17, 2026
MustangBetts
M
T
Looking for some help with 2006
  • thedudeillest
  • Mar 16, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 20, 2026
