help with temp issues. won't get over 130*
  • Thread starter Thread starter fivespeedsteed
  • Start date Start date Nov 22, 2008
fivespeedsteed
20+ Year Stangneter
Oct 17, 2003
748
22
69
Richmond, VA
Nov 22, 2008
  • Nov 22, 2008
alright so my cars always run one tick on the gauge above 130. which still seems cold. now that its cold out it won't even get up to 130. my heat works a little so its getting some temp, but is there a way I can see if my thermostat is stuck open? my dads was in a truck he had once and it wouldn't get any temperature and heat blew cold. any ideas?
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Nov 22, 2008
  • Nov 22, 2008
First off, what gauge are you reading 130 on?
The stocker can be horribly innaccurate, mine used to go up 15% just by turning the headlights on.
Also sounds like it's time for a new thermostat.
Brian@PAR
86
Phoenix AZ
Nov 22, 2008
  • Nov 22, 2008
Cold engine. Pull the radiator cap and start it up. If coolant is circulating the T-stat is stuck open. Since you have no heat my bet is that is your issue. Yeah and changing the T-stat is a PITA due to it's location. I always change the bolts to allen head as it make it easier for the next time it comes out.
hotcobra03
poteet,tx
Nov 22, 2008
  • Nov 22, 2008
Sounds like missing or open tstat.pull it out and look .
fivespeedsteed
20+ Year Stangneter
Oct 17, 2003
748
22
69
Richmond, VA
Nov 22, 2008
  • Nov 22, 2008
i am reading on the stocker, but its pretty acurate i think for what it is. the heat is nothing to warm up in, its like lukewarm air... i forgot you can open the rad. cap and see if its flowing, good call. thanks man.
old_blue
1,783
282
124
Nov 22, 2008
  • Nov 22, 2008
agreed with above. sounds like a stuck t-stat. I dont remember having too many issues with replacing mine. I know the bolt to pulley clearance sucked but still do-able.
betke76
20+ Year Stangneter
Oct 23, 2004
241
9
laurel, md.
Nov 23, 2008
  • Nov 23, 2008
yea t-stat is stuck open flowing coolant all the time, put a new thermostat and gasket, and it will go around 170-200 degrees and have hot heat to warm you up on these cold days
hotcobra03
poteet,tx
Nov 23, 2008
  • Nov 23, 2008
A fail safe tstat is made to stick open .maybe u get lucky.seen that on tv show
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Nov 23, 2008
  • Nov 23, 2008
Change it. It's stuck open. My girlfreinds Grand Prix's T-stat is stuck open. Car has the Check Engine light on. I scanned it yesterday and the code is the T-stat. I'm changin it Tuesday along with the coolant.
dp88
40
#10
  • Nov 23, 2008
  • #10
Thank god someone else has this problem. mine stays one notch above 130 as well. It sucks getting all the way to work and the car still isnt warm enough to heat up, i can see my breath inside the car for 30 mins.
vristang
4,933
101
124
Seattle
Nov 23, 2008
#11
  • Nov 23, 2008
  • #11
I'm curious.... Is there a sensor installed to check the function of the Tstat?
How does the ecu know the Tstat is the cause???
Were any of these cars converted from 2.3 engines?
ShortThrow50
923
Pa
Nov 24, 2008
#12
  • Nov 24, 2008
  • #12
Id like to know what the outcome is. I ave the same issue with my toyota. The first thing i did was replace the thermostat and it made no difference so its not stuck open thats for sure
SVT32VDOHC
3,501
28
119
Motor City
Nov 24, 2008
#13
  • Nov 24, 2008
  • #13
I'm not sure on the stangs, but the Snap-On scanner just told me it was the T-stat. It gave me the code P0128 I think it was and it said "Thermostat". I didn't get to install it today, because I had to pick up my Cobra, but I'm doing it tomorrow.
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
