  • 2005 - 2009 Specific Tech
Help With Throttle Body Issues
  • Thread starter Thread starter Neggy
  • Start date Start date Jan 30, 2017
N
Neggy
  • Jan 30, 2017
Hi guys, hoping you can help me. I've got 2008 saleen 302 e that keeps going into safe mode. I've been looking at the car over the last few days, it's had a new tps, I've cleaned the maf sensor and the throttle body, I've checked and cleaned the connections to the tps and to the tac. I went for a drive and pulled 3 codes p2111, p2112 and p2104. All these codes seem to point to the throttle actuator control. Apparently the return spring has been checked, are there any other checks I can do to the tac or would I have to buy a new throttle body complete? The car has only done about 12000 kms. Are there any checks that can be done to the pcm? Any ideas where I can go from here? Thanks!
SpartaPerformance
2,517
61
89
Long Island NY
Feb 6, 2017
  • Feb 6, 2017
Sounds like a bad TB, do you know what is outfitted on that vehicle?
N
Neggy
  • Feb 6, 2017
Yes that's what I'm now thinking after a bit more research, it's a 55mm ford unit. I've checked the resistance on the throttle actuator control and I'm getting .3 ohms and I think it's meant to be above 1. I've ordered a throttle body so I'll let you know how I go!
N
Neggy
  • Feb 25, 2017
Just to help anybody if they get this kind of issue I thought I'd put a response up. I ordered a new throttle body off eBay but unfortunately when I recieved it it was damaged, so I cut my losses and just fitted the throttle actuator control motor off the new one instead of changing the whole lot and it has been all good since, touch wood!
Help finding throttle body
  • jpmaxx
  • Apr 21, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 22, 2026
jpmaxx
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
Electrical Stumped No Start...
  • sydhawk
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
sydhawk
