  • SN95 4.6L Mustang Tech
HELP WITH TRANSMISSION
  • Thread starter Thread starter ilocanoStangGT
  • Start date Start date Mar 25, 2006
I
ilocanoStangGT
  • Mar 25, 2006
i have a 96 mustang GT auto with transmission problems.
1) When i initally launch on first, i would have to release the gas then gas it again in order for it to switch onto second.
2) When on third gear, i hear a ticking noise.
any ideas or suggestions? Resorting to replacement of transmission (if needed) will be costly.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 25, 2006
  • Mar 25, 2006
Have you ever changed the fluid and filter?
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Mar 25, 2006
  • Mar 25, 2006
i agree have you done a fluid and filter change try that first and see what happens then we can go from there
d98gt
4,505
59
204
SE Texas
Mar 25, 2006
  • Mar 25, 2006
Rebuild kits aren't all that expensive for the 7r40w transmission. If you are capable of pulling the transmission yourself then getting someone to rebuild it for you, it won't be all that bad. However, I just got my car back from a rebuild (I wasn't able to pull the tranny myself and such) and it cost me $1600. That includes new torque converter, shift kit, and the other suggestions.
1st and 2nd gear were the gears which went out on me.
best of luck at fixing the problem
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Mar 25, 2006
  • Mar 25, 2006
definately consider doing the J-Mod. its a lot safer than a shift kit, seeing as how it was designed by the guy that designed the 4r70w.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 25, 2006
  • Mar 25, 2006
www.tccoa.com
T
TGJ
1,049
  • Mar 25, 2006
I got some bad news for you. The J-Mod is not going to save your transmission.
I have some even worse news for you. Those problems sound like the intermediate one way roller clutch is toast and that means its rebuild or replacement time.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Mar 25, 2006
  • Mar 25, 2006
agreed
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Mar 25, 2006
  • Mar 25, 2006
i actually agree with the rebuild idea. when you are in there its the perfect time to upgrade. also make sure you regularly maintain your trans. put in this pan F8UZ-7A194-AA and drain and fill the trans every few oil changes.
I
ilocanoStangGT
#10
  • Mar 26, 2006
  • #10
Thanks everyone!!! imma see what can be done. ill repost later for updates.
d98gt
4,505
59
204
SE Texas
Mar 26, 2006
#11
  • Mar 26, 2006
  • #11
If you do end up going with a rebuild, I suggest you get a new torque converter along with a transmission cooler.
I
ilocanoStangGT
#12
  • Mar 26, 2006
  • #12
any specific torque converter or transmission cooler? and what you think about the shift kits?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Mar 26, 2006
#13
  • Mar 26, 2006
  • #13
get the biggest tranny cooler you can fit in the car. for shfit kits, if having a professional shop do the rebuild, they can figure out the j-mod. you find it confusing if youve never seen a valve body off or dont have the trans in front of you.
d98gt
4,505
59
204
SE Texas
Mar 26, 2006
#14
  • Mar 26, 2006
  • #14
Check summit for a B&M unit. Shouldn't be too expensive
T
TGJ
1,049
#15
  • Mar 27, 2006
  • #15
Get a decent tranny cooler, the B&M unit is okay. There is some better ones though.
If you choose to rebuild that transmission, build it to 98 or newer specs, those years had better parts. I would suggest you find an 01 - 03 4R70W out of a mustang and swap that in. It is not a direct swap, you will need to make changes, but you will find these cheaper than rebuilding and you will have a better 4R70W.
I would suggest you replace the rad as well and flush the system, to get the garbage out from the bad tranny. Some run a filter to do this.
I would look at a good single plate TC. Do a search for more info.
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
