Help with vacume tree
  • Thread starter Thread starter millhouse
  • Start date Start date Jul 12, 2004
millhouse
1,985
Simpsonville, SC
Jul 12, 2004
  • Jul 12, 2004
I recently noticed that I have an unatached vacume line on the passenger side vacume tree. There is 1 inlet, and 2 outles. The inlet and one outlet are hooked up fine...but there is one that has no line coming out of it, and there is a slight vacume leak there.
I disconnected my smog sytem quite a long time ago, and cant remember if I had plugged it, or if it is supposed to be connected to something else.
I'll get some pics if I can.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 12, 2004
  • Jul 12, 2004
Two large hoses connect to the vavuum tree, on suction from the intake manifold, one from the power brake booster. One small hose goes to the controls for the A/C, Heater & vent. The remaining port is unused in stock applications & is capped.
millhouse
1,985
Simpsonville, SC
Jul 12, 2004
  • Jul 12, 2004
Hmmm, if it's supposed to be capped, I guess the cap must be gone. All thats left if a spot for one of the plastic vacume lines to plug into, nothing else.
ALMOST STOCK
1,250
41
88
CA.
Jul 12, 2004
  • Jul 12, 2004
millhouse
In the diagram below are you referring to item 58 (Vacuum Check Valve) or item 43 (Vacuum Distribution Tee)?
I think (and I could be completely wrong here ) that jrichker was referring to the Vacuum Distribution Tee when he referred to the
but like I said I could be completely wrong.
J
jwcma
70
Bay Area, CA
Jul 12, 2004
  • Jul 12, 2004
One port on the tree (#43 in illustration) is for the cruise control. I think it's labeled "S/C".
dgollem
20+ Year Stangneter
May 5, 2004
212
33
49
Waldorf MD
Jul 12, 2004
  • Jul 12, 2004
The vacumm tree on the passenger side number 58 on the picture (I think) on my car has 3 hoses, the hose on the end connects to the tree on the drivers side, Number 43 on the pic, the next fitting over connects to a small hard plastic vacumm line and runs in the firewall (for the HVAC control maybe), and the last one runs in another hard plastic line into my passenger fender area (god only knows why, it must snake out somewhere else). My car is an 88 speed density with a 5 speed. Hope this helps some.
J
jwcma
70
Bay Area, CA
Jul 12, 2004
  • Jul 12, 2004
The third line going into the passenger fender is connected to the vacuum reservoir "ball". It maintains your hvac settings when the engine sees little/no vacuum.
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
C
Paxton novi 1200SL
  • Cambo617
  • Oct 9, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Oct 9, 2025
Cambo617
C
Electrical Need help identifying what these electrical items are (93 LX 5.0)
  • dan50
  • Apr 11, 2026
Fox 5.0 Mustang Tech Apr 12, 2026
dan50
Engine 1990 5.0 bogs and pops over half throttle
  • Sander
  • Aug 1, 2025
Fox 5.0 Mustang Tech Aug 2, 2025
AeroCoupe
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
