help with wires and fuses
apollo1701
i have four problems i'm trying to solve with my car.
1. is there a certain path that one needs to fish the heater cables through the dash area for them to work. i keep getting bent and broken cables. i can make it to the heater box and connect them but the middle one always buckles and doesn't move the item. plus which one of the cables goes to the front and which to the back on the long cables.
2. interior door lights...door jam switches connected, and harness plugged in but the interior lights don't come on. taillights work and get power but rear seat lights not working.
3. where does one get a short 20amp fuse to fit into the 67 fuse box...all the ones i find are too long...can you use a different fuse?
4. radio connections...what wires under the dash are you suppose to use?
thanks [email protected]
1) You can't bend them sharply at the control end.
2) They are on the same circuit as the under-dash lights. Trace the wiring.
3) If you local auto parts is too lame to have these, you can order whatever you need from Glazier Nolan.
4) There is a special plug near the ignition switch with one small and one large connector. If this is cut off, you'll have to adapt something. The radio plug is available from Glazier Nolan.
