Help, Wont start
  • Thread starter Thread starter nseand
  • Start date Start date Jul 7, 2007
N
nseand
9
  • Jul 7, 2007
I just picked up an 87 with the maf conversion and a ton of work done on it but it wont start. Gets spark, has press gague on the fuel rail and reading close to 40 lbs. I am getting voltage ath the injectors, and spark. I have replaced the plugs, the module on the dist, cap, rotor, coil, plugs ( plugs were wet when I took them out) . Even tried spraying starter fluid in the throttle body and nothing. Turns over, has compression just wont fire. I am going to replace the pickup on the dist this week and cross my fingers. The car was rarely started in several years as it sat in someones garage, they said last time it ran for 5 sec and never wood start again. The fuseable link (20 ga) was corroded so I replaced that. Fuel pump comes on and primes as well. I was thinking bad gas, but put in a bottle or 2 of gas conditioner incase there was water back there, but I am at a loss here. The last thing I want to do is have it toed somewhere and pay an arm and a leg. ANy thoughts?
9
90bluecoupe
76
Abingdon md
Jul 8, 2007
  • Jul 8, 2007
Move the distributor alittle at a time and try to start it, the timming could be way out and it wont start.
N
nseand
9
  • Jul 8, 2007
been there tried that. Since it was running before and the dist was never moved, I have a hard time believing it to be the dist. I pulled the cap to make sure the rotor turned to be sure the timing chain didnt break, and the rotor turns just fine. It gets spark, gets fuel ( not sure if the fuel is bad( but even bad fuel should ignite. It wont even crank on starter fluid when I spray it, but it gets spark like a champ. Plugs are wet, can smell gas, computer gets power, injectors get power, all power at the fuseable links, fuel pressure says it is close to 40lbs after the regulator, fuel pump primes , any other thoughts?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 8, 2007
  • Jul 8, 2007
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
Revised 29-Jun-2007 to update TPS testing procedure for 94-95 Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. See paragraph 5A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire with the switch in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position, then the fuse link is blown.
H.) Computer
J.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) A noid light available from any auto parts store, is one way to test the injector wiring.
The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.99 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
N
nseand
9
  • Jul 8, 2007
been on the checklist and following it, doesnt seem to help ///////////I get spark and I get fuel................could it be a bad mass air? or pip in the dist? I have replaced everything in the dist BUt the pip, figure for $20 I might as well do it too. Does anyone know if they can test the computer if I take it somewhere?
HISSIN50
34
129
Jul 8, 2007
  • Jul 8, 2007
Just keep going down the list and you should find the cause.
FWIW, if you have spark and injector pulsing, your PIP should be fine. While replacing parts is great, you really dont want to introduce more variables. Get the car running and then if you want, replace items one at a time (so if there is an issue afterwards, you dont have to wonder which of 20 parts caused the issue).
Good luck.
N
nseand
9
  • Jul 8, 2007
since there is spark and it is getting fuel, would you drain the tank or start looking at sensors and or computer?
HISSIN50
34
129
Jul 8, 2007
  • Jul 8, 2007
Where are you at on the checklist?
This helps everyone stay on the same page. For instance, I have no idea what having fuel means. To me it means the fuel rail is seeing 30+ PSIG of fuel pressure, but it could also mean you have injector pulsing I suppose.
Because you have voltage to injectors and spark, your computer should be fine. Again, keep running the list because it will save recursive chasing of one's tail or testing systems you have deduced to be ok. And don't skip steps. If you need something like a noid light, it's worth it to hit the store, spend 5 bucks and get one. It can save lots of time with erroneous troubleshooting; there's logic in the order in which JRichker constructed his list.
We just wanna see you get it fixed and back on the road as soon as possible and for the least cash outlay.
Good luck.
N
nseand
9
  • Jul 8, 2007
well if I am getting spark AND fuel then #6 would apply, unless I am reading this wrong????Unless the spark wasnt strong enough to ingite the gas? I am probably going to drain the tank , change the gas filter, and then start from square one. But since it has spark and has gas, it has to be a sensor or somehting. I know you said go in order but I have. I get power to the injectors, plugs are wet, AND it has spark. which eliminates almost the whole list, right? Just for ****s and giggles i am going to drop in a new distributor.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 8, 2007
#10
  • Jul 8, 2007
  • #10
The last time I had your problem, it turned out to be a weak coil. I had enough voltage to jump a gap while testing. I did not have enought voltage to jump a gap with normal engine compression.
N
nseand
9
#11
  • Jul 8, 2007
  • #11
My thoughts exactly, I replaced the coil and the distributor today, still have orangish bluish spark. I am seriously considering dumping all the gas and going from there. I am getting messed up readings from the tps. I took a file and elongated the holes to make it adjustable and got the key on voltage on the green wire to 1.02 but it is over 4 on the wot.... Still looking at the maf sensor and debating. I am the type that will replace it all before I take it elsewhere. SO I am on new coil, replaced fuseable link that looked worn, new dist, new module, new pluge, wires are fine, 12.93v at the injectors, power to the eec, fuel pump primes and comes on, 36lb press on the rail...............I am getting in the pissed stage..................... been thru a case of beer as well.
HISSIN50
34
129
Jul 8, 2007
#12
  • Jul 8, 2007
  • #12
Also if you haven't, give it some time. Your plugs might be fouled (in my experience, shutting the injectors off if they're fouled badly doesnt do much. Gotta let 'em sit or remove and clean 'em).
Good luck.
N
nseand
9
#13
  • Jul 8, 2007
  • #13
thought of that too, have new plugs in it as well. pulled a plug hooked it to a plug wire, and we have spark.
F
FourBy4Toy
#14
  • Jul 12, 2007
  • #14
Did you find out your problem? I am having the SAME exact problem, I was hoping you found a soultion??
Nemesis2k4
15
#15
  • Jul 13, 2007
  • #15
didnt read the other posts because my laptop is sloooooow but my 4 cyl had the same problem i replaced the crank sensor and timed it and vroom staarted right up
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
  • brandyn200
  • Jun 20, 2026
AeroCoupe
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
