HELP zex nitrous install
  • Thread starter Thread starter importkiller90
  • Start date Start date Sep 16, 2007
I
importkiller90
59
iowa
Sep 16, 2007
  • Sep 16, 2007
i know this system is idot proof (but im an idot) could someone please tell me where to hook up the red,white and black wires and the intake hose and the regulator hose (on the zex box) and what to do with the hose that goes from the regulator to the intake on my car? please be easy on me im new to nitrous
stevesLX
373
cincinnati
Sep 17, 2007
  • Sep 17, 2007
The red wire goes to the toggle switch to arm the nitrous system. The black wire is ground. The white wire goes to the green wire that comes off your throttle positioning sensor. The throttle positioning sensor is the thing that sits on top of your throttle body. There should be 3 wires comeing off of it,Green, Orange, and black. The green one is the wire you need to hook the white wire up to. The regulator hose comeing off the nitrous management unit goes to the vacum port on your fuel pressure regulator. And the intake hose goes to the back of the manifold where your vacum line for your fuel pressure regulator use to go. You can just take the hose that goes from the manifold to the regulator right now and throw it in your tool box you wont need that anymore since you will be using the vacum lines off the nitrous management unit. The unit itself should be marked regulator and intake. If you go to www.zex.com and over on the left side of the page click on product info and then over on the right side click on installation instructions it will give you a list of every product they offer and just click on your kit which I would assume is V8 dry kit 82015 (it is the 11th one down on the list of nitrous systems) and it will give you the instructions on how to do it all. Make sure you follow these because if you are using the dry kit you need to program the nitrous management unit to activate under WOT.
I
importkiller90
59
iowa
Sep 17, 2007
  • Sep 17, 2007
holy crap i am an idot
I
importkiller90
59
iowa
Sep 17, 2007
  • Sep 17, 2007
what is the black botton on the back of the nitrous mangement unit?
stevesLX
373
cincinnati
Sep 17, 2007
  • Sep 17, 2007
The black buton is what you use to program it. Also just to make sure you wired it right. The arming switch should have 2 red wires. The one with the fuse holder on it goes to a 12v source and the other red wire off the switch goes to the red wire off the Nitrous management unit. Also you need to make sure you are using the correct fuel jet with the correct nitrous jet for whatever horsepower shot you are wanting to use. The fuel jet goes in the connection where the regulator line hooks up to the NMU and the nitrous jet goes into the nozzle that sprays the the nitrous. the jets are numbered according to the info I will give you at the end of this post. Now back to the black button, Turn the vehicle's ignition on but do not start the car. Turn the nitrous arming switch to the ON position. Go to the Nitrous management unit and push the black switch in. Look at the NMU's operation light. It should be red. Its in the learning mode. Go back into the car and press the gas pedal to the floor and hold it there for 10 seconds. Now go back to the NMU and the light should be flashing continuously from Red to Green to off. Now go back inside the car and turn off the nitrous arming switch and then turn it back on. Now go back up to the NMU and the light should be a solid green. The system is ready and should activate under wide open throttle now. Now go back and prees the gas pedal to the floor a couple of times you should be able to hear the silenoid click each time the pedal gets to the floor. Also very important do not ever ever program the NMU with the bottle turned on or any nitrous in the line. Also you should never activate the nitrous under 3000 RPM's and you should use a colder plug or and close your gap on the plugs to around .035. Make sure you are running 93 octane gas and retard your timing once you start spraying more than 100 shot. Heres a chart.
75 hp 100hp 125
Nitrous Jet 40 46 52
Fuel Jet 43 40 38
Ignition Retard 0 degrees 2 degrees 4 degrees
I
importkiller90
59
iowa
Sep 17, 2007
  • Sep 17, 2007
thanks alot man, i got the autolite 24's and i just need to gap them and retard my timing to about 10 or so, can i run race fuel with nos? and if so how much?
stevesLX
373
cincinnati
Sep 17, 2007
  • Sep 17, 2007
yes you can but I wouldn't run a whole lot of it. I personally haven't done it but I know of people that have. When I get home tonight I will talk to my neighbor and find out. I dont know if you have ever used NOS before but if you haven't you need to be ready especially if you are on street tires because if you activate it in 1st or 2nd gear with street tires you are probably going to spin the tires off unless you have a passanger with you. I personally wouldn't try it in first gear on the street. Now at the track with slicks hold the rev up to 4000 and let it rip as long as your tranny and suspension can handle that hard of a launch with spray.
I
importkiller90
59
iowa
Sep 17, 2007
  • Sep 17, 2007
yeah this is the first time using nitrous i dont plan on using it untill at least 3rd gear i had one guy tell me it will put the fear of god in me when i use it i hope it does
strtrcr50
Previously from Dirty Jerzey exit 7a
Sep 17, 2007
  • Sep 17, 2007
Your friend has watched too many movies. Use it the minute you can stick the tires.
I
importkiller90
59
iowa
Sep 17, 2007
#10
  • Sep 17, 2007
  • #10
will it spin the tires at 80 or so ?
strtrcr50
Sep 17, 2007
#11
  • Sep 17, 2007
  • #11
Well, I have no idea about racing a half mile since I only run 1/4. I race at the track. That being the case, you can run real tires. Quite a few of my friends come out of the hole spraying on slicks. On a set of ET streets, you won't spin at 10 mph, let alone 80.
C
cjnecessary
70
richmond,in
Sep 18, 2007
#12
  • Sep 18, 2007
  • #12
With street tires and an 80 shot I had problems getting traction at the track. That was in any gear, new bfg d/r's and I dont have that problem anymore.
I
importkiller90
59
iowa
Sep 19, 2007
#13
  • Sep 19, 2007
  • #13
how big of slick can i fit on a stock 15X7 rim? the car has a 1 1/2 in drop all the way around if that matters
C
cjnecessary
70
richmond,in
Sep 20, 2007
#14
  • Sep 20, 2007
  • #14
Slick or drag radial?
I
importkiller90
59
iowa
Sep 21, 2007
#15
  • Sep 21, 2007
  • #15
what about both?
C
cjnecessary
70
richmond,in
Sep 26, 2007
#16
  • Sep 26, 2007
  • #16
I'm running a 275/50/15 dr on an 8 inch rim w/ no problems
I
importkiller90
59
iowa
Sep 26, 2007
#17
  • Sep 26, 2007
  • #17
ok thanks
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
  • dan50
  • Jul 18, 2026
dan50
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
A
need help and advise
  • amps1956
  • Oct 14, 2025
  • Other Auto Tech
Other Auto Tech Oct 21, 2025
Mcmahst
