Help!
  • Thread starter Thread starter MUSTANGJOE
  • Start date Start date May 5, 2005
MUSTANGJOE
Silver Stanger
1,644
17
59
May 5, 2005
  • May 5, 2005
Hey guys..
I have a serious problem!..I brought my car to the shop this week to changer my clutch, fix headers leak and install 3.73 gears. But when they drove it they said that theres something really wrong with my car!! . They told me its missing torq and power. They are going to do a compression test this week to see if its my engine.
My question is...what can cause this?..I hope its not the engine, but if it is what does that mean, do I need a rebuild?
Help!!!!!!!/////// Thanks
Sicarius428
2,085
May 5, 2005
  • May 5, 2005
How many miles do you have on the car? Has the aod ever been rebuilt?
Kevin
MUSTANGJOE
Silver Stanger
1,644
17
59
May 5, 2005
  • May 5, 2005
Kevin
It has 80 000/m, its a 5 speed..but it seems to be ok. Can it be a vacum leak or something stupid!..I hope, I don't feel like spending $$$ on this now!
thumper460
3,022
Orange Park , Fl
May 5, 2005
  • May 5, 2005
Careful..!! Low on torque and HP could be a ..........???? What did it feel like when you took it in>>?? If the compression is low in all cylinders.. and then they do a wet test and the compression comes up.. it is rings!! Befor you go into an Over haul with ONLY 80 K on the engine.. maybe get more advise!! COOL??
Just me....................
Thumper
cmb91LX
432
Memphis
May 5, 2005
  • May 5, 2005
maybe "they" caused the problem with the car
it is not unheard of
5spd GT
"the 5.0 owns all"
9,516
Arkansas
May 5, 2005
  • May 5, 2005
Yeah I hate to put this out there but I wouldn't doubt if they messed something up or broke something either during the install or when they went to drive it...
I would never let someone drive my car without me there...and if that is the case I'll take the keys
seijirou
2,417
DFW
May 5, 2005
  • May 5, 2005
Low on power? based on what? I would get a second opinion.
MUSTANGJOE
Silver Stanger
1,644
17
59
May 5, 2005
  • May 5, 2005
Thanks guys..
They didnt install anything yet, they just drove it to get a feel of the clutch since I said it was bad. My brother works at the shop so I dont think they screwed around with it. Also I always felt the car was missing power, just thought it was normal thats why I purchased the 3.73 gears to wake it up a little... anymore opinions?? Thanks again.
J
jerry beach
2,671
Ocala,FL
May 5, 2005
  • May 5, 2005
That would shy me away from them too. The fact that they told you that means they were out getting on it. Thats why my car goes in for alignment only and I dont let anyone drive it. I pull it onto the rack and back out, and I test drive it. If they have a problem with that, they dont get my business.
And if you have a stock engine, gas mileage is a good indicator of general engine health and tune. If you see it dropping off, its time to check things out. I get anywhere from 16-20mpg in the city and 25-28 hwy. Thats a healthy stock engine at 132,000mi.
Sicarius428
2,085
May 5, 2005
#10
  • May 5, 2005
  • #10
Sorry what was I thinking AOD... duh new clutch... Anyways 80K isnt bad at all... I would get a second opinion too. Do a basic tuneup... filter, sparkplugs, wires maybe, fuel filter(possibly clogged) and check vacuume, compression, timing and spark. Possibly pull the codes but that is a good place to start.
Kevin
Sicarius428
2,085
May 5, 2005
#11
  • May 5, 2005
  • #11
How would they know that your car was missing power anyways? Did they dog your car around the block or something?!? If so thats wrong...
Kevin
seijirou
2,417
DFW
May 5, 2005
#12
  • May 5, 2005
  • #12
Kevin
that's why I'm wondering where this basis of low power comes from.
70lightning
205
in the basement makin stuff
May 5, 2005
#13
  • May 5, 2005
  • #13
Kill them kill them all, how would they know it was down on power unless they were out hot roding it,
And a sliping clutch can make a car feel slow.
MUSTANGJOE
Silver Stanger
1,644
17
59
May 5, 2005
#14
  • May 5, 2005
  • #14
Thanks guys!
Trust I'm just as paranoid as you guys when I bring my car tp the shop. I'm always thinking that they will go around joy riding. But I just spoke to my brother he said he just took it up and down the street and that he didnt do anything stupid.
They will be doing a compression test this week, The clutch does feel weird(cheap), Anyways i'll just wait and see what the results are as for the compression goes , I just hope its nothing serious...watta way to start the season! .
Can a bad U-joint cause this problem?..I find its mostly low end torque and power thats missing. I hate leaving my car in these places(my baby!) But I have no choice..it needs to get fixed!
HISSIN50
34
129
May 5, 2005
#15
  • May 5, 2005
  • #15
u joints should not be causing your issues. if your brother works there (and you are not comfy working on it), can he and you do the compression testing yourselves?
good luck.
J
jpyjfrdmstng
64
Dodge, BC
May 6, 2005
#16
  • May 6, 2005
  • #16
clean the maf
MUSTANGJOE
Silver Stanger
1,644
17
59
May 6, 2005
#17
  • May 6, 2005
  • #17
Would pulling the codes indicate that theres something wrong with the MAF or other things, even though the check engine light is not on?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 6, 2005
#18
  • May 6, 2005
  • #18
Yes.
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $33.
MUSTANGJOE
Silver Stanger
1,644
17
59
May 7, 2005
#19
  • May 7, 2005
  • #19
thanks
Electrical Dash wiring
  • RileyDymond
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 19, 2026
RileyDymond
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Wednesday at 4:21 AM
JD1964
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
  • brandyn200
  • Jun 20, 2026
AeroCoupe
