Help
  • Thread starter Thread starter 935point0
  • Start date Start date Oct 26, 2006
9
935point0
A House
Oct 26, 2006
  • Oct 26, 2006
Couple of days ago, I was driving home and my 93 5.0 started to over heat. Within a mile from my house, I hear a loud poof (it wasn’t a pop,) come from under the car. It sounded as if I blew a radiator hose but they are intact. As soon as this happened, the car didn’t die but I lost torque and horsepower and barely rolled into my driveway. After it cooled down, I can start it and it will run but its running very ruff. I’m not getting any smoke nor do I have any leaks of any kind. At first I thought it might be a piston but I am not hearing any kind of metal clanking or anything like that. Could this be a head gasket? It seems like the timing may be off also. I know its hard to diagnose things over the net but any ideas what to check would be nice. I have not done a leak down test yet. Could it be a bad cat?
Thanks,
Jeff
stang22
1,318
Washington, D.C.
Oct 26, 2006
  • Oct 26, 2006
What color is your oil?
9
935point0
A House
Oct 26, 2006
  • Oct 26, 2006
Oil looks good, doesn'y seem to have any water or metal in it.
HISSIN50
34
129
Oct 26, 2006
  • Oct 26, 2006
Have you checked to see if any cylinders are dropping? A cylinder balance test is a nice way to check this.
Good luck.
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
A
Electrical electric mirror switch issue...
  • alchemist1
  • Apr 18, 2026
Fox 5.0 Mustang Tech Apr 19, 2026
2000xp8
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
