HELP
  • Thread starter Thread starter banks98stang
  • Start date Start date Sep 2, 2010
1 of 2 Next Last
banks98stang
57
  • Sep 2, 2010
OK SO I WAS DRIVING HOME AND THIS LADY CUT ME OFF I HIT THE BREAKS N MY CAR TURNED OFF I WAS LOW ON GAS....OK SO WE LETTHE CAR SIT AND THEN IT STARTS AND MY TEMP GAUGE IS GETTING HOTTER N HOTTER AS I HIT THE GAS BUT WHEN I LET OFF IT GOES BACK DOWN....SO I TOOK OFF THE THERMOSTAT N PUT SOME GASS AND IT STARTED I STARTED T0 DRIVE HOME AND AS I RUN HIGH RPMS MY TEMP GAUGE SHOOTS UP AND MY BATTERY LIGHT TURNS ON BUT WHEN ITS SITS OR RUNS AT LOW RPMS ITS RUNNING AT OK TEMP
dgollem
20+ Year Stangneter
May 5, 2004
212
33
49
Waldorf MD
Sep 2, 2010
  • Sep 2, 2010
You might want to check out your seprintine belt or belt tensionioner. It could be slipping at higher RPMs affecting both the water pump and alternator. Good Luck.
banks98stang
57
  • Sep 2, 2010
MY BELT SLIPPIN IS SOLVED BUT NOW THAT IM NOT RUNNING A THERMOSTAT ITS STILL GETTING HOT AS I ACCELERATE I DRAINED THE RADIATOR N REFILLED IT WATER PUMP IS GOOD
HISSIN50
34
129
Sep 2, 2010
  • Sep 2, 2010
Why not reinstall the t-stat? Are you using an aftermarket instrument to measure temp?
TenorPlayinGuy
1,208
Canyon Country, Ca
Sep 3, 2010
  • Sep 3, 2010
With any cooling system theres only three components: Level, Sealing, Flow
Make sure your coolant level is up. Fill the radiator with the engine running, let the car heat up with the cap off. You will also find if there is flow at this time (Without a T-stat you should see flow instantly) If there is no flow, you have a bummed pump. You could also rent a pressure tester to make sure you don't have leaks but check your level and flow first. Those are easy.
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,112
224
Massachusetts
Sep 3, 2010
  • Sep 3, 2010
Please don't type in caps. Thank you.
madspeed
Colonel Mustard
1,332
204
a van down by the river
Sep 3, 2010
  • Sep 3, 2010
My eyes are hurting after reading that one...
Bills89GT
127
Canton CT
Sep 3, 2010
  • Sep 3, 2010
Try to replace the thermostat. I have seen this before and it seems that without the thermostat there was nothing to slow the flow down and the coolant was unable to cool in the radiator
madspeed
Colonel Mustard
1,332
204
Sep 3, 2010
  • Sep 3, 2010
Put a stat in there for gawds sake
banks98stang
57
#10
  • Sep 4, 2010
  • #10
i put a 160 stat in and im thinking its electrical now for some reason when i run the car at 4k rpm then let the roms go down my temp goes up ?
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Sep 4, 2010
#11
  • Sep 4, 2010
  • #11
Are you looking at the right gauge?
boboli
22
Tucson Az
Sep 4, 2010
#12
  • Sep 4, 2010
  • #12
If the temp gauge goes up with rpm's and the battery light comes on, you probably have an electrical issue, since your alternator is charging more as the rpm goes up. i would seriously doubt your car stalling would cause engine overheating issues.
Does a mustang have a voltage limiter in the cluster or am I thinking of another brand? If it does maybe its your problem
HISSIN50
34
129
Sep 4, 2010
#13
  • Sep 4, 2010
  • #13
The cluster uses a voltage regulator to limit the effect of electrical changes on gauge readings.
boboli
22
Tucson Az
Sep 5, 2010
#14
  • Sep 5, 2010
  • #14
HISSIN50 said:
The cluster uses a voltage regulator to limit the affect of electrical changes on gauge readings.
I thought I remembered that correctly.
So could this regulator be causing his gauge issues. Maybe it can't maintain the voltage especially with the increase in alternator output at higher rpms. Of course I don't know why this would set off the battery light but its just my hypothesis.
HISSIN50
34
129
Sep 5, 2010
#15
  • Sep 5, 2010
  • #15
The IVR should not be the source of the issue. It uses a VREF that's less than half that of battery voltage.
A bad ground could be the issue (especially if the gauge reading changes if the headlights are turned on).
An secondary temperature reading (aftermarket gauge, etc) is also needed.
Bills89GT
127
Canton CT
Sep 5, 2010
#16
  • Sep 5, 2010
  • #16
He already solved the battery light problem, his belt was slipping causing overheating and low voltage. he took the tstat out and fixed the belt, he still had the overheating problem so he put in a 160 degree thermostat and now has a different issue..
Why did you put the 160 degree tstat in? Whenever I have any issues with my vehicles I put stuff back as close to factory as possible. I'm not sure what your car is exactly but the factory one for me is a 195 iirc. Stupid little things like that are what always seem to screw me lol
BrokenPony
15
#17
  • Sep 6, 2010
  • #17
Isn't the 160 stat too cold? Think about it... at 160, the stat opens... so it's probably always open once the engine heats up. If the coolant is always flowing it doesn't have a fair chance to cool off in the rad. Install a proper stat. Maybe the temp drops at higher rpms because the fan is pulling more air thru the rad?
mycaptainchris
98
Houston, TX
Sep 7, 2010
#18
  • Sep 7, 2010
  • #18
check that the water pump spins freely. i.e. Take the belt off and turn the pump by hand.
banks98stang
57
#19
  • Oct 28, 2010
  • #19
im still having the electrical problem nothing as far as cooling system...
its only when i hit a bump my battery light comes on i had my alternator tested and that isnt the problem. i havent been driving the car just have it parked in my garage
HISSIN50
34
129
Oct 28, 2010
#20
  • Oct 28, 2010
  • #20
Have you wiggle tested the wiring? The little stator wire is the first one to check. In addition to the regulator wiring, don't forget the battery cables and power distribution stud.
It could also be the internals of the alt flexing. You can't replicate that in a bench test very easily (I suppose you could hit the alt with a rubber mallet during the bench test).
1 of 2 Next Last
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
