  • SN95 4.6L Mustang Tech
help!
  • Thread starter Thread starter duzy
  • Start date Start date Aug 24, 2011
duzy
80
jacksonville fl
Aug 24, 2011
  • Aug 24, 2011
I've got a 03 gt and when I hit a certian rpm my car almost feels like it misses, or sort of like sputters. I ran it empty and put new gas in it twice to make sure it wasnt water in the gas. What you guys think the car only has 71,000 miles on it, and i've only had it for 2,000 miles.
Rick 91GT
Mustang Master
95
99
PA
Aug 24, 2011
  • Aug 24, 2011
Id be checking all electric connections and grounds first...
trinity_gt
3,125
81
99
Canada
Aug 24, 2011
  • Aug 24, 2011
What RPM?
Under heavy load or cruising? Or both?
Any malfunction codes? MIL on or flashing during this episode?
Any mods on the car?
Jhunter
68
  • Aug 24, 2011
Let me guess, it's around 1300 rpms when it does it. And usually in a high gear at constant speed around 1300 rpms. If these are close then good luck. Some say the iac, maf, egr, vacuum leaks, trq convertor, burnt trans fluid. And maybe even more. Some have cured it and some live with it. But if it's not this then I hope you find it.
duzy
80
jacksonville fl
Aug 25, 2011
  • Aug 25, 2011
well my maf housing is cracked and doesnt always line up with the air filter and i really dont know the rpm cause my gauge is off i need to get a tac soon
Jhunter
68
  • Aug 25, 2011
That cracked MAF housing may be leaking enough to throw it off. There's just been so many causes and fixes to this same sorta problem your having it could be a trial and error thing to fix it or take it to a good dealer/shop and have them machine it to find what problems are going on. That can be costly but so can replacing parts you aren't sure are bad. When you do find it, it would be nice to repost the fix. one more thing others can do for there surging.
I have an auto and mine does it or around 13oo-1400 rpms which puts me around 40 mph give or take when i'm poking through town. At 55mph no problems, hard acceleration no problems. slow accelleration it would surge or lug sorta getting to speed. It's just that one little spot.
duzy
80
jacksonville fl
Aug 27, 2011
  • Aug 27, 2011
i got a new un cracked MAF from a junk yard and it semmed to stop the sputtering and spitting for now.
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Acceleration Vibration
  • Blown02svt
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
General karthief
  • Gulftown980x
  • Jul 29, 2026
squeak93
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
