Help
  • Thread starter Thread starter 91 5.oh
  • Start date Start date Jan 14, 2013
9
91 5.oh
  • Jan 14, 2013
I have a 91 lx hatch that surges at idle and under load stalls on stop sometimetimes and has lack of power i keep getting code 96 something with the fuel pump relay im getting good fuel pressure and power to the relay is this an easy fix and im just a dumb ass or where should i go from here
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Jan 14, 2013
  • Jan 14, 2013
search - Idle surge check list follow it religiously and post results as you go . and more info about the car whats done to the motor etc would help in a helpful answer
9
91 5.oh
  • Jan 14, 2013
thanks for the direction toolow91 the car has bbk cold air egr and spacer honned plenum and lower intake gasket matched factory heads hooker super comp shortys stock h pipe and cats maximum motor sports subframe connectors 4 wheel baer disc brakes and ford racing 3.73s i will update as soon as i get done
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Jan 14, 2013
  • Jan 14, 2013
no problem. That list was compiled by a knowlagable member on here and do not deviate from it as it is listed as most common issues to least common.
J
jka
5 Year Member
Jan 17, 2010
339
23
29
Jan 14, 2013
  • Jan 14, 2013
Remove the battery and check the fusible links an ground wires and make sure everything is tight and in good shape. Install the battery and start the car and let it idle then drive 10-15 miles and check the codes again it should be gone . I just had the same problem a code 96.. after i change the fuel filter.. sometimes it's the simple things that will cause stupid codes ..like bad ground wires or a loose wire. Also i had the same code two years ago and it went away..if you slam the trunk too hard sometimes you will get that code.
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
Jan 15, 2013
  • Jan 15, 2013
why is he playing with fusible links ? car runs link is either good or bad ..... checking grounds and such is never a bad thing but the surging idle check list gets to that
J
jka
5 Year Member
Jan 17, 2010
339
23
29
Jan 15, 2013
  • Jan 15, 2013
I told him to check and see to make sure it's not any fusible links that are burning up/ and open circuit/broken wire anywhere..because that would cause a code 96. And a bad or loose ground wire would also cause idle surge and stalling.. also a vacuum leak would cause surge/stall. With wiring ..either good or bad ..please check because broken wiring will cause this code and if the computer keeps this code in the memory your car will idle bad and stall. That's a nice idle surge check list and it's very helpful but sometime's it's good to check everything..because something simple will cause alot of problems and will cause you to spend alot money. Also check the cutoff switch in the trunk ..because you can slam the trunk too hard and it will cause this code 96. I had the same problem before.. you car will run with a code 96 .. but it will not idle good plus it will stall on cold start alot. Also did your car idle bad before the code 96? if so try cleaning your throttle body.
J
jka
5 Year Member
Jan 17, 2010
339
23
29
Jan 15, 2013
  • Jan 15, 2013
Also did you get a code 11 first and then a code 96?
9
91 5.oh
  • Jan 25, 2013
sorry for the delay while driving the other day it seemed like it was missing bad so when i got hom left it running and pulled plug wires while running to find it sure enough nothing getting thru the wire for number 6 replaced wires and car runs alot stronger without surging under load ran codes and am still getting 96 with the 11 first also now getting 41 and 91 and car still feals alittle under powered and still stalls on stops randomly also sometimes it feals like it will scream like it used to still going thru checklist as i get time thanks again for the help
J
jka
5 Year Member
Jan 17, 2010
339
23
29
Jan 25, 2013
#10
  • Jan 25, 2013
  • #10
If you got a code 11 first and then a 96 as a memory code don't worry. But sometimes a code 41 and 91 will cause the computer to throw a code 96. I have seen when there is a wiring problem in the o2 sensor harness and or the o2 sensors are bad you will get a code 11 41 91 and a memory code 96. Your engine may be running lean..causing your car to stall and lose power. Have you replaced the o2 sensors lately?
9
91 5.oh
#11
  • Jan 27, 2013
  • #11
not since ive had the car i checked for continuity in the ground for the 02s, the orange wire on the back side of injector harness, to the battery as well as the body and its grounded i do not have an analog multi meter to test the 02s i will look up prices for the 02s and when checking over it i did a wiggle test on the computer ground plug and it failed i am going to replace the wire as far back as needed and see if that helps anything i am hoping this is the problem cause between that and only hitting on 7 i had a hard time beating my buddys pretty much stock 88 gt
U
No fuel pump relay in harness
  • Uli661
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
Uli661
U
W
Need help! 1989 mustang
  • wickedzach487
  • Mar 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
AeroCoupe
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
G
Help! 93 Mustang 2.3L A4LD dies at idle
  • goofyfoot53
  • Nov 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
goofyfoot53
G
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
