Engine Hesitation/backfire problem solved
  • Thread starter Thread starter JohnG
  • Start date Start date May 19, 2021
J
JohnG
38
San Antonio, Texas
May 19, 2021
  • May 19, 2021
How many miles can I expect out of my factory fuel injectors? I have over 250K miles on the originals. When should I expect them to die or start having problems?
evintho
20+ Year Stangneter
Nov 12, 2003
683
246
73
Santa Rosa, CA.
May 20, 2021
  • May 20, 2021
I'm sure at least some of the pintle caps are cracked/broken, rubber O-rings are toast and they're probably dirty if not clogged by now with a quarter million miles on them. Either have them cleaned and flowed or buy some new injectors. I'll bet you notice the difference!
2000xp8
SN Certified Technician
Aug 8, 2003
8,056
1,641
194
NJ
May 21, 2021
  • May 21, 2021
It's fairly rare that they fail.
You will know if it happens.
With 250,000 miles, there is plenty of other stuff i'd be worried about before the injectors.
Reactions: General karthief and Boostedpimp
R
Rubberball
  • May 23, 2021
I agree it's fairly rare they fail . . . BUT they can get dirty to the point that the spray pattern is affected adversely which can negatively complete combustion and thus power levels. Add in the fact that people rarely change the car's fuel filter and that the original fuel tank and lines are most likely rusty after all these years, etc.
J
JohnG
38
San Antonio, Texas
May 23, 2021
  • May 23, 2021
I have been running a lot of injector cleaner through them lately. Mainly Lucas, with a dozen or so tankfuls of fuel. So, I am thinking they are not too dirty. Could the o-rings have broken or split? Maybe the pintle caps? My symptoms act like a lean mixture. I have gone over the engine several times and have not found a vacuum leak. I am wondering if an o-ring has split and is sucking air there.
7991LXnSHO
wanna catch the space herp
7,387
2,745
194
Kearney, NE
May 23, 2021
  • May 23, 2021
New o rings on both ends of the injectors are cheap if you have any doubt at this mileage.
Mustang5L5
Mod Dude
Feb 18, 2001
43,305
18,012
224
Massachusetts
May 25, 2021
  • May 25, 2021
There are fuel injector kits that will replace all those parts plus the screens.
Pardon Our Interruption...
Use a good quality O-ring lube for install.
J
JohnG
38
San Antonio, Texas
Jun 21, 2021
  • Jun 21, 2021
I was having a persistent problem with hesitation, backfiring up through the intake, and general misfiring and running badly. Classic vacuum leak symptoms. I went over the vacuum lines many times and found nothing. The ECM was only showing code 94, but not 44. I went through the thermactor system a couple of times to verify it was correctly working. It was. The cylinder balance test showed nothing. Compression test showed all cylinders good or better-than-good. Fuel pressure was running 42 without vacuum and 34 with. Then I got to thinking the old, original injectors may be clogged or something. Maybe split o-rings or shattered pintle caps. So, I pulled them and ran carb cleaner through them. None were dirty and the spray patterns were all OK. I had been running tons of injector cleaner through the car for months prior, so I felt the injectors SHOULD be clean. The original o-rings were in surprisingly good condition, and few pintle caps showed any degradation. Put on new o-rings and pintle caps. Put it all together and it ran worst than before. Thinking I had got some of the injector connectors crossed, I pulled it all apart again and found no problems. Then, when I put it all back together again, it still ran badly, but read a 1 on the balance test. Swapping plugs and wires from 1 to 2 did not change anything. New cap and rotor changed nothing. Swapping injectors 1 & 2 moved the balance test results to 2. Installed a rebuilt injector this weekend and it runs like new again. AND, the persistent 94 code went away. Balance test returns a happy 9. I believe the injector was failing slowly, and only showed a problem under load, maybe this is why the balance test did not see it. The engine did idle nicely and started every time without an issue. So, I am thinking that the 94 code was kind of a red herring. There was no problem with the thermactor. The computer may have been seeing the lean mixture from cylinder 1 and could not tell what the problem was. But in the end, I still have 7 of the original injectors in there and functioning nicely.
I am thinking the injectors should be better quality than this. I mean, it is ONLY 30 years of daily driving with ONLY 270K miles. I'm thinking, WTF??? (sarcasm flag raised high here).
I'll put this car's quality, year for year, mile for mile, up against any other make or model, foreign or domestic.
Reactions: jrichker and McFly2
nickyb
I gotta say i never painted my nuts, Never Ever
3,009
1,645
163
nevada
Jun 21, 2021
  • Jun 21, 2021
Agreed,our foxes were built Ford tough.
J
JohnG
38
San Antonio, Texas
Jun 23, 2021
#10
  • Jun 23, 2021
  • #10
Not only that, But Quality is JOB 1!!
I love how she runs now. If I can only get the cruise control working...
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
Hello Im new here but have been solving problems on my 90 LX for years.
  • Potomus Pete
  • Aug 19, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 19, 2026
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
  • brandyn200
  • Jun 20, 2026
AeroCoupe
  • Mindseye007
  • Aug 16, 2026
Mindseye007
