  • 1994 - 1995 Specific Tech
Hesitation, help
  • Thread starter Thread starter TrueBlue95GT
  • Start date Start date Oct 17, 2004
TrueBlue95GT
966
Connecticut
Oct 17, 2004
  • Oct 17, 2004
If I'm decelerating in gear and I just go from closed throttle to WOT the car waits about 2 seconds and sounds like it's missing and then starts to accelerate. Also, sometimes after driving for a while, my car misses when I give it more than 3/4 throttle. What could this be from?
HISSIN50
34
129
Oct 18, 2004
  • Oct 18, 2004
have you pulled codes yet?
good luck.
94Silverbullet
488
MD
Oct 18, 2004
  • Oct 18, 2004
some guesses:
plugs
wires
fuel filter
distributor
bad fuel
water in tank
dirty air filter
dstanggt50
1,316
Woodinville, WA
Oct 18, 2004
  • Oct 18, 2004
I had a bad hesitation problem, turned out to be maf, I would clean the maf, and like others have said, chk plugs, wires, fuel filter, cap, rotor, and chk for codes.
L
lietuvis91
102
NO, LA
Oct 18, 2004
  • Oct 18, 2004
I have the EXACT SAME problem and have not cleaned the maf yet. My friend seems to think that maybe the EGR system is clogged up so that maybe another possibility. We'll sheck the egr valve sometime soon. At first I thought it was cap/rotor/wires, but after going all msd for those parts still have that problem. I noticed most poeple say that cleaning the maf fixed their probelm. If i get to check on it I'll let you know.
TrueBlue95GT
966
Connecticut
Oct 18, 2004
  • Oct 18, 2004
I cleaned the MAF a while ago, I have a fairly new cap, rotor, wires, plugs, filter. I do need to clean my K&N, and i think I've been running rich and my plugs might be fouled. Would this cause the problem?
dstanggt50
1,316
Woodinville, WA
Oct 18, 2004
  • Oct 18, 2004
Fouled plugs could cause a hesitation problem. My maf wasn't necesarily dirty, I had a friend @ a Ford dealership, used their "star" tester thing to measue the voltage @ idle, was really low, .51 or something., replaced w/my factory maf (had pro-m at the time) and ran better. Maybe put your stock maf back on to see , or see if your tweecer can show you maf voltage??
mystang94gt
951
Bay Area, CA
Oct 18, 2004
  • Oct 18, 2004
A bad egr was my coulrpit. I changed everything above except the MAF and I still had problems. I ran codes and my EGR was at fault. I think if your running really rich it can cause the EGR to go bad. I'd say get your hands on a code scanner and see what it says.
TrueBlue95GT
966
Connecticut
Oct 18, 2004
  • Oct 18, 2004
By the way, I deleted my EGR. I run the codes the old fashioned blinky light way and the only codes that come up are the rich oxygen sensors codes. I changed the oxygen sensors about 10,000 miles ago.
J
Lack of power on acceleration
  • jameshernandez
  • Aug 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2026
jameshernandez
J
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Monday at 5:18 AM
manicmechanic007
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
