  • SN95 4.6L Mustang Tech
Hesitation on some start ups?
  • Thread starter Thread starter jbmax112
  • Start date Start date Jun 27, 2009
J
jbmax112
15
Miami Lakes, Fl
Jun 27, 2009
  • Jun 27, 2009
Hey you guys, ive had my car for a year now and on some occasions when i start my car when its warm, it hesitates a little. Is this normal for fords because my girls explorer does it to>! i currently have 53K on my 2002 stang, should i change the plugs?
thanks
:SNSign:
isjoining
143
Orlando, FL
Jun 27, 2009
  • Jun 27, 2009
i have this problem as well, only happens on warm starts...don't know what the hell is causing it.
Flghtmstr1
572
Springfield, PA
Jun 27, 2009
  • Jun 27, 2009
It's normal. My car has done it ever since I got it, and I'm sure a lot of other people will chime in here soon enough with the same sentiment.
You might want to think about changing the plugs anyway with 53k on them. It's not necessary, but you're probably leaving a couple of hp on the table.
281CI96Coupe
233
  • Jun 28, 2009
It drives me crazy, I have it on GT as well. I do not know what causes it...The only thing comes to mind is not the proper amount of fuel is being used to turn over, or maybe the injectors need a cleaning..who knows...
AdRock
521
South Texas
Jun 28, 2009
  • Jun 28, 2009
When you turn the key to the run position you should hear the fuel pump run for a few seconds then shut off. Try cycling the key so that the fuel pump primes 2 or 3 times before you start it. See if that makes any difference.
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
  • Gulftown980x
  • Jul 29, 2026
squeak93
  • Mindseye007
  • Aug 16, 2026
Mindseye007
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
