hesitation.....what is causing it?
  • Thread starter Thread starter tprzeus
  • Start date Start date Mar 28, 2007
T
tprzeus
  • Mar 28, 2007
My 1966 Stang is a 6 cyl and runs great absent hesitation upon acceleration. We have cleaned the carb, replaced plugs, wires and distributor. What else should we be looking at? Again, the hesitation is only upon accelerating, and otherwise runs even.
rbohm
6,698
550
204
tucson,az
Mar 28, 2007
  • Mar 28, 2007
first get rid of the stock load-o-matic dist, and replace it with a duraspark dist from a later model small six. i got one from a 78 fairmont, and hooked it to a chrysler ignition box. it works great. second add ignition timing untill you get detonation, then back off the timing a few degrees. that should eliminate the hesitation.
ratio411
3,870
73
109
Pensacola FL
Mar 28, 2007
  • Mar 28, 2007
Could be a carb issue in the accellerator pump circuit.
There is more to it than just cleaning the carb.
There are usually adjustments to be made in that part of the carb.
If you open the throttle plates without a shot of fuel to carry the carb into it's main circuit, then you just get a 'hole' in accelleration until the main can catch up to your throttle plates.
That said, I don't know your carb in particular.
However, I know about carburation in general and the principle is the same.
Do some looking and find out how to adjust the carb you are dealing with.
Dave
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
2K
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
