Hey when my car is running in the driveway and I rev it up, it kind of hesitates a little. For example if I bring it up to about 2500rpm and then stab it, it takes a second for it to react. Any ideas?
Try cleaning your throttle body. Mine was sticking alittle between shifts and had a slight hanging idle. So I decided to get some intake cleaner. I ended up geting the valvoline SynPower stuff as it wasn't much more than the other stuff.
Detach the air intake from the TB. Take some rags and stuff them under the throttlebody to catch run off (there will be a lot). Have a friend sit in your car and hold the throttle down (with it off ) if you can't get help you can work the plate by hand but this can be a PITA if you need to scrub any spots. Next spray the crap (literally) out of the throttle body. Use a rag or a toothbrush to get the more stubborn stuff. You should get some nasty stuff running out of the TB. Next have your friend pump the gas slowly so you can spray the TB plates pivot (lots of crap gets stuck in here and moving the plate back and forth really seemed to work it out for me). Try to wipe what you can clean and dry and reattach the airduct.
Afterwards the car might have trouble starting due to all the cleaner and junk thats in the intake. Mine took about 30 secs and then ran real rough (like shaking the car rough)for about 5 mins. Afterwards I went for a short drive to help pull all the crap out of my intake.
I saw a huge improvement in my cars performance. Leaving the driveway I gave it a little to much and left a nice patch. My RPMS still hang a bit so next I'm going to tackle the IAC and EGR.
Hope this helps. Costs about 3 bucks and takes about 30 min.
